Thread: help: removing a stuck oil drain plug
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #1 Re: help: removing a stuck oil drain plug
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    The first set is the set I was talking about.
    help:  removing a stuck oil drain plug Attached Images
  2. #2 Re: help: removing a stuck oil drain plug
    Pennsylvania
    Meh.
    Clamp on to the bolt by whatever method you prefer.
    Get the oil or pan good and hot... by driving or torch.
    Then hold some dry ice on the bolt for a couple minutes.
    Then hammer at it.
  3. #3 Re: help: removing a stuck oil drain plug
    Jul 2013
    Summertown Tn
    Is the pan aluminum or steel?
    I agree with getting the bolt hot if it's a steel pan. If it's aluminum you could make matters worse by heating it.
  4. #4 Re: help: removing a stuck oil drain plug
    Pennsylvania
    '04 is steel.
  5. #5 Re: help: removing a stuck oil drain plug
    Jul 2013
    Summertown Tn
    Oh ok. Wasn't sure.
  6. #6 Re: help: removing a stuck oil drain plug
    GT Level Member orange57's Avatar
    Aug 2012
    Chandler, AZ
    Yep, its steel. Tried heating it with no luck. This by far the most stubborn bolt I have ever dealt with in my 16 years of working on my own cars. Maybe I should just drill and tap a new hole ha ha
  7. #7 Re: help: removing a stuck oil drain plug
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Suck the oil out through the dipstick.
    http://www.edmunds.com/how-to/the-to...il-change.html
    1997 Red GTP 182000 miles stock
  8. #8 Re: help: removing a stuck oil drain plug
    Aug 2012
    Chandler, AZ
    Quote Originally Posted by GTP in RTP View Post
    I also thought about this too. But there is a small drip from the plug,in fact the only oil drip. So I would like to get a crush washer in there.
  9. #9 Re: help: removing a stuck oil drain plug
    Jul 2013
    Summertown Tn
    Did you get a set of those erwin bolt extractors yet? I haven't had one fail me yet. Even on round cold roll at work.
  10. #10 Re: help: removing a stuck oil drain plug
    Aug 2012
    Chandler, AZ
    Quote Originally Posted by Twizted 1 View Post
    Not yet. I plan to pick up a set today or tomorrow.
    matt
  11. #11 Re: help: removing a stuck oil drain plug
    Jul 2013
    Summertown Tn
    Hammer on the smallest size that will fit.
    Then give'er hell. I'm pretty sure it'll come out.
  12. #12 Re: help: removing a stuck oil drain plug
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    6-POINT SOCKET ONLY, maybe try both metric or sae?
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  13. #13 Re: help: removing a stuck oil drain plug
    Feb 2013
    Woodbridge NJ
    Use a pipe wrench. The longest one you can get on the bolt and still turn the wrench.
    Don
  14. #14 Re: help: removing a stuck oil drain plug
    Jul 2013
    Summertown Tn
    Neither. One of these
  15. #15 Re: help: removing a stuck oil drain plug
    Aug 2012
    Chandler, AZ
    Twizted1, those look very similar to the Irwin set that Autozone has. I have a credit at Autozone and plan to get the set today or tomorrow. I figure it will be the most reliable and hopefully easiest way to get the plug out.
  16. #16 Re: help: removing a stuck oil drain plug
    Jul 2013
    Summertown Tn
    You hit the Nail right on the head.
    The set below it are from matco, same thing just deeper and more of a selection.
    I think that's going to be your easiest way to get that out. Be sure to use the one that feels like it barely wants to start on the bolt. Then Hammer the **** out of it.
    Put your Biggest 3/8"ratchet on it and go to Strainin!! Lol
  17. #17 Re: help: removing a stuck oil drain plug
    SE Level Member Jake U's Avatar
    Apr 2013
    Waukesha, WI
    use a cheater bar if you have room to get under there for some extra leverage
  1. Drain Plug in Trans pan
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 11:32 AM
  2. drain plug oil leak
    By 05grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 02:34 PM
  3. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  4. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
  5. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
