Thread: Drain Plug in Trans pan
Results 1 to 12 of 12
  1. #1 Drain Plug in Trans pan
    Donating Users timboku's Avatar
    Montgomery, IL
    Anyone know how to do this? Searched and could not find anything. Is it worth it?
  2. #2 Re: Drain Plug in Trans pan
    Nov 2009
    Grand haven
    Not really unless you are goin to be changing your trans fluid a lot.
  3. #3 Re: Drain Plug in Trans pan
    Montgomery, IL
    Thats what I thought. I dont really plan to but thouht might be easier but I am sure the cost to do it will out weigh removing a few bolts.
  4. #4 Re: Drain Plug in Trans pan
    Niagara
    Theres no point. When you change your transmission fluid, you have to drop the pan to change the filter anyway
  5. #5 Re: Drain Plug in Trans pan
    Banned - Busted For Scamming
    Feb 2009
    Actually there is a big point, alot less mess when you go to drop the pan. You should change your tranny fluid every 30k anyways. Go to advance auto or autozone they actually have them on the shelf for a couple bucks, drill a hole and put it in. I have one on my trans and love it!!
  6. #6 Re: Drain Plug in Trans pan
    Montgomery, IL
    If its only a couple of bucks it cant hurt. The zzp one is like 100 bucks so I think I will run to autozone. Do you know what it is called?
  7. #7 Re: Drain Plug in Trans pan
    Wichita, KS
    I brazed in a threaded sleeve onto the pan, unscrew, drain and less of a mess like it was said above. The ones you drill and add in are kinda like a nut and bolt set up, with a hole through the middle. They have gaskets, and will seep over time, so I went with the more permanent approach.
    I use the top of a plastic 55gal drum barrel as my drain pan. Its big enough that you can hit your target when you drop the pan when its full easy enough.
    I change my GTP's tranny fluid once a year. The girlfriends GTP every 50K miles. 30K miles I feel is a little too short lived for the fluid for a normal driver, but if your racing it time to time, than ya, 30K would be good.
    ~F~
  8. #8 Re: Drain Plug in Trans pan
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    X2
    Very good idea
  9. #9 Re: Drain Plug in Trans pan
    Jul 2008
    sumter,south carolina
    get aluminum ZZP pan like me, not only does it come with drain plug.... keeps trans temps a lil cooler.
    02 GTP with mods 05 GP for DD
  10. #10 Re: Drain Plug in Trans pan
    Donating Users Fast50dz's Avatar
    MN
    Now knowing the sell them. i about to go order one ha
  11. #11 Re: Drain Plug in Trans pan
    Jul 2008
    Tampa, FL
    i bought a 15 qt. oil catcher thing from wal-mart when i did my tranny drain. i worked all the bolts on one side and loosened them so that fluid only dripped from one side. it worked pretty well actually. i wouldn't put a hole in my pan...i'll just use this method from now on...
  12. #12 Re: Drain Plug in Trans pan
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  1. Radiator drain plug
    By bishdog25 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:40 PM
  2. drain plug oil leak
    By 05grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 02:34 PM
  3. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  4. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
  5. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
