So this morning I was changing the abs wire harnesses on my sons '04 GT. I started the car and drove it up on ramps. Spliced in the new harnesses and went to start the car. No dice. Engine does not turn and I do not hear the solenoid engage. I checked the fuse panel under the hood and checked fuse #24 (good) and relay # I think 32 (good). Used a multimeter and have 12.7 at the battery. I have power to the solenoid. I had my daughter turn and hold the key to start to check the ignition wire and get no juice. So I figure it is an ignition switch issue. That is unless I have forgotten to check something. Any ideas?
Don
