Thread: 2004 Grand Prix GT2 won't start (short circuit)
Results 1 to 12 of 12
  1. #1 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    Hello!
    I tried to start my 2004 Grand Prix GT2 after 11 day while I was travelling, but it would not crank. I could hear the starter unsuccessfully trying to start.
    I figured my battery wasn't holding charge properly, so the first attempt was to charge with jumper cables to an SUV; and it wouldn't turn over. 2nd attempt was a small battery booster, again it wouldn't turn over. Three's a charm though, and the third try with a commercial-grade battery boost got my car running. This got me home from 250km away (4 hours later), through a gas station, picking packages up, and crossing the border without shutting my car off. All the way, at least a dozen times 'Charging System Failure' came up on my dash computer, especially when hitting high revs while passing other vehicles.
    So I get into my driveway, shut the car off, and try to restart it... nothing. It won't crank again.
    I don't think it's the alternator because I drove for 4 hours without issue.
    I don't think it's the starter because the engine did crank with a commercial boost hooked up in parallel; it just took a lot more power to get it going (the external connection).
    I removed corrosion from both terminals and re-seated the cables but this didn't seem to change anything.
    I removed the negative battery clamp from the negative terminal, and with a multimeter was able to see a 12-14V difference between the two components. I also saw a voltage difference between the negative terminal and the engine... which leads me to believe the positive battery cable is shorting to the chassis somewhere. I removed fuses one by one from the engine compartment fuse block but I wasn't able to track the source of the short - this leads me to believe there are more than one shorts to the chassis, or that the short is off of the main positive terminal cables.
    Are there any common points of failure on the 2004 Grand Prix for the battery cables? Is there an easier way to diagnose which component failed/where the short is?
  2. #2 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Grand Rapids, MI
    Hm, well you could check all the grounds. There is one right under the battery, if the 04+ have the same as 97-03 which I believe they do. Again, if they're the same, there's also 3 on the transaxle stud above the starter (access from the top), another on driver strut tower.
    But imo I'd take it to advance or something and let them check both the alternator and battery and just rule it out and go from there.
  3. #3 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    Forgot to mention the following:
    We took the battery to Canadian Tire, had then test it and give it a charge and it was fine. It went from 12.1V to 12.6V, and was still pushing 800 CCA. I also disconnected the alternator power that sits under the rubber cap, and was still seeing 12V from chassis to negative terminal.
  4. #4 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    I pulled all the fuses from the fuse box and put them back one by one. 4 of the fuses cause my multimeter to read 12V:
    Fuse 26 (BATT MAIN 1 40A)
    Fuse 27 (BATT MAIN 2 50A)
    Fuse 30 (BATT MAIN 4 30A)
    Fuse 16 (PCM/ETC 15A)
  5. #5 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    Pulled the starter out and bench tested it with jumpers, the bendix popped out and was fine. Anyone have any ideas?
  6. #6 Re: 2004 Grand Prix GT2 won't start (short circuit)
    You say the starter unsuccessfully tried to start the car. Do you mean the bendix popped out and the starter didn't spin the motor over? That's power related and I think you've covered most of the power stuff. Hopefully something you cleaned up was the culprit.
  7. #7 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    When the starter was being powered off the wiring harness, there didn't seem to be enough power to get it to fire properly to start the engine, so we thought the starter might have gone bad. Pulled it out and bench tested it using jumper cables, and it ran properly. The bendix popped up and it spun up pretty fast. Looked at it carefully, didn't have any dead spots. So I think there's enough current leaking from somewhere that's causing the starter to not run when connected to the electrical system.
    With respect to the fuses, what I was seeing was if any of the 3 MAIN BAT fuses were in, the 12V from engine to negative terminal was detectable. If those 3 fuses were removed, and the PCM/ETC fuse was in, then I could still measure 12V difference. Is there a way to find out what those 3 MAIN BAT are providing power for? I leafed through a few electrical diagrams in my Hanes manual but didn't see the fuses labelled properly.
  8. #8 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    Negative terminal to PCM (in the air cleaner housing) has 12V too...could be the PCM shorting out? Or it's registering that voltage due to the short to ground elsewhere. I'll try disconnecting the PCM cables tomorrow to see if the short persists.
  9. #9 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Ontario
    I bet its one of your battery connections. the 04+ battery connections suck !
  10. #10 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    Can you be more specific? :P
    Edit: Found Wiring Specs for the fuses. http://imgur.com/a/MzNLh
    BATT MAIN 1: Connected to instrument panel fuse box fuses
    BATT MAIN 2: Connected to instrument panel fuse box fuses
    BATT MAIN 4: Connected to the blower motor control processor
    Fuse 16: Connected to the PCM and generator? Looks like there's also some sort of connection to the EBCM too... (the sharp dotted line, not the long dashes)
  11. #11 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    Unplugged the three connectors from the PCM, and the short persisted so I reconnected it. I disconnected the remote positive terminal, and the short disappeared. Re-connected it to continue plugging away.
    Pulled all the fuses in the instrument panel fuse box, didn't make a difference.
    Disconnected a lot of the under-the-hood connectors, but wasn't able to narrow it down. Starting to run out of ideas. There are a few more connectors that I want to try getting at from the underside tomorrow when I put the starter back in.
    Could the fuse box be faulty somehow?
  12. #12 Re: 2004 Grand Prix GT2 won't start (short circuit)
    Sep 2011
    Ontario, Canada
    At a loss for words. Re-connected everything, and my car started up. Will check tomorrow if there's still a short, didn't get the chance since my neighbour who helped me put my starter back in hammered my negative terminal on pretty tight. Also hoping it starts tomorrow morning ran it for 20 minutes to make sure the battery charged.
  1. Tail lights "short circuit" too much lately (wires burned)
    By Haulero in forum General Tech Discussion
    Last Post: 12-25-2010, 09:18 PM
  2. Engine won't start after very short trip
    By corky in forum Introductions/Noob Questions
    Last Post: 07-20-2010, 05:44 PM
  3. short ram intake for a 2007 grand prix
    By tino153 in forum General Tech Discussion
    Last Post: 10-24-2009, 10:17 PM
  4. Possible short in tilt column = no start?
    By randye in forum General Tech Discussion
    Last Post: 08-12-2009, 03:13 PM
  5. P0508 Idle Control System Circuit Low on 2000 pontiac grand prix
    By Bigkamp22 in forum General Tech Discussion
    Last Post: 07-17-2009, 12:29 PM
