Thread: Is it recomended to get wheel align after instaling lwr cntrl arms with ball joints ?
Results 1 to 7 of 7
  1. #1 Is it recomended to get wheel align after instaling lwr cntrl arms with ball joints ?
    Feb 2013
    Ohio
    Wheel alignment after replacing lower control arms with ball joints ?
  2. #2 Re: Is it recomended to get wheel align after instaling lwr cntrl arms with ball join
    Wouldn't hurt.
  3. #3 Re: Is it recomended to get wheel align after instaling lwr cntrl arms with ball join
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    sure its part of the steering system
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  4. #4 Re: Is it recomended to get wheel align after instaling lwr cntrl arms with ball join
    you'll know how bad you need one after your done installing the new lca's, if the wheel is off, and it pulls, take it in asap.
  5. #5 Re: Is it recomended to get wheel align after instaling lwr cntrl arms with ball join
    Mine didn't pull or anything after swapping lca's but my tires wore funny. I'd do it just for piece of mind.
  6. #6 Re: Is it recomended to get wheel align after instaling lwr cntrl arms with ball join
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    any time any part of your suspension is replaced or adjusted, you need to realign
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  7. #7 Re: Is it recomended to get wheel align after instaling lwr cntrl arms with ball join
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    For my personal preference I would do it but at the end of the day if you cant afford it just yet then your alignment would be fine at least for a lil while anyway. You shouldn't have to change the tie rod threads which will change your Toe angle and you shouldn't have to touch the strut bolts(camber bolts) which would change your Camber. So your not directly affecting your alignment angles but removing one of the main components (LCA) and hitting the components to release the LCA could definitely knock the alignment off slightly definitely the Toe since that's the most sensitive. I would definitely get am alignment.
    If you haven't done so yet, I recommend going to FireStone and paying a one time fee for $170.00 for lifelong free alignments whenever you need it. You'll get your money worth just after your 2nd alignment(most shops charge an average of $80 for each alignment you get
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  1. 99 GTP Ball Joints
    By schwarry in forum Brakes/Suspension/Chassis
    Last Post: 04-03-2013, 02:44 PM
  2. Tie rods or ball joints
    By Cedric in forum Introductions/Noob Questions
    Last Post: 04-15-2011, 06:21 AM
  3. Replacing Ball Joints
    By 98GTPCALGARY in forum Brakes/Suspension/Chassis
    Last Post: 06-07-2009, 05:12 PM
  4. ball joints
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 05-07-2009, 07:45 AM
