Thread: I need more valve lift out of my heads...
Results 1 to 15 of 15
  1. #1 I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    I am looking for techniques to increase valve lift on our L67 heads. I would like to run the Intense Stage 2 cam with YT 1.7 rockers for a total of .565/.575 lift. My machinist is already rebuilding my heads as well as a P&P job but he is not familiar with these heads. I'm trying to explain to him but he giving me the "just because someone said on the Internet" response. So, can someone explain to me how to explain to him where to make the cuts and how much?
    Just tell me what other info you need. The heads will have the ZZP modified retainers, SS valves (intake enlarged to 1.9), ZZP modified retainers, 105# springs, Viton seals, P&P job (gasket match), and hopefully cut for S2/1.7 valve lift.
    Patiently waiting for the gurus...
  2. #2 Re: I need more valve lift out of my heads...
    May 2008
    Schuyler, NE
    Tell him to take .1" off the top of the valve guides, and chamfer the newly created edges to make installing the valve seals easier.
  3. #3 Re: I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    So I talked to him again telling him just what you suggested. His response was that "the only way to get more lift is to cut the spring pocket or a longer valve." Whose right/wrong/crazy? Someone please be a tie breaker. He supposed to be the best in town so I'd hate to move the work but I'm at a loss and stuck as he is standing strong.
  4. #4 Re: I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    I'll try that, but the new twist is the heads which I bought as part of my top swap here in the "for sale" section are BOTH cracked. He magnafluxed them today and found it. I bought them 6+ months ago.
    What do y'all think? Do I dig up the seller and give him crap or is it too late? I'm pretty pissed today! I had just got into the game and paid him on the higher end of the going rate (out of ignorance at the time) for them.
  5. #5 Re: I need more valve lift out of my heads...
    May 2008
    Schuyler, NE
    Most 3800 heads are cracked, due to the way they were cast.
    Have them do a pressure test on the heads. I'm guessing that they will be ok. They are very thick in the area where they tend to crack.
  6. #6 Re: I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    So people run them cracked?!
    Ill have a pressure check done if I can run them like that. I knew a certain casting lot was known to crack but I thought that meant they were shot.
  7. #7 Re: I need more valve lift out of my heads...
    May 2008
    Schuyler, NE
    Yup. The heads on my 04 were cracked, but I've been running them anyways. I've got close to 15k miles on them.
  8. #8 Re: I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    I read a little and see this is normal'ish. Thanks for keeping an over reaction under lid.
  9. #9 Re: I need more valve lift out of my heads...
    Feb 2009
    flintnasty MI
    Dont let him port the heads. 99% chance he is going to ruin them.
  10. #10 Re: I need more valve lift out of my heads...
    The Boss Iceman6669's Avatar
    Jun 2011
    Why do you say that?
    2011 F-150 Yote powered
  11. #11 Re: I need more valve lift out of my heads...
    I know a local that went through 8 sets to find two non cracked. By mistake I dropped one of my 01 heads off and sure enough it had cracks. The cracks are between the valves.
  12. #12 Re: I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    What would you suggest then? Just a polish job, stock heads just cut for lift and 1.9 intake valve? I can't pay 1300 for the heads from one of our vendors. I planned on using the Intense S2 cam.
    So run the cracked heads (w/ minor cuts for the comment above) or find some non-cracked before I complete my swap?
  13. #13 Re: I need more valve lift out of my heads...
    Feb 2009
    flintnasty MI
    Quote Originally Posted by slimguns View Post
    That would be the best. I had some heads ported and they came out nice and I know that I didnt lose power, but they were not worth the money so far as they didnt make any gains in their own right.. also the guy said he ruined ~5 sets just to figure out what worked the best.
    Shelling out money for vendor heads is my suggestion if you feel you need to have ported heads.. I have ran stock heads and ran at the top of the record boards for years, not sure why I went the ported head route... stock worked fine for me.
  14. #14 Re: I need more valve lift out of my heads...
    Jun 2011
    Just take .100" off the valve guides..
  15. #15 Re: I need more valve lift out of my heads...
    May 2012
    Albuquerque, NM
    Ok. Thanks guys. Will do. Thanks.
  1. Series III S/C heads new bronze valve guides anyone do it? please read
    By theonlysi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2012, 09:56 PM
  2. Fixed broken valve spring, Still misfiring heads are off
    By Kasey in forum General Tech Discussion
    Last Post: 09-19-2011, 08:06 AM
  3. 90# valve springs on '97 heads
    By DanGTP in forum General Tech Discussion
    Last Post: 08-11-2008, 01:32 AM
