ill have to get that checked out tomorrow then. Lets just say it "passes" the load test. Then What?
i dont think it will. if all your doing is jumping it and it starts fine than it points to the battery or connection problems. how old is your battery ? what happens if you turn on the headlights and try to start it ?
These guys have it right. First thing I would check, cause it is the easiest is the battery terminals. Make sure they are clean, no corrosion (that means taking the terminals out and cleaning the threads, and tight. It that doesn't fix it, probably bad cell in the battery. If that is the case, don't try to charge it, you can have pieces of a bad battery then.![]()
