how low is low boost, what turbos front and rear?
GTX3076 up front. 6262 precision in the back
14-15 psi on both on the street which netted me a better 660 feet ET due to a better launch
At the strip with the glue I felt I needed more boost.
So front engine is the same. I start 10 psi then ramp up to 15 psi. Rear engine 22 psi from the start.
On my other cars I ran up to 29 psi. Of course gains are not huge from 20 psi to 29 psi because of the trans slipping.
So I would expect stock trans if it would hold up 3-4 tenths quicker at full boost on both engine.
But I think the biggest gain will be 1st gear starts and built trans that actually put down the full power when I raise the boost.
