Thread: Aluminum cradle swap question
Results 1 to 10 of 10
  1. #1 Aluminum cradle swap question
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    My Regal was recently damaged. It has a L26 block swapped in place of the original L67, a "top swap". When the swap was done the Aluminum oil pan was used, and the original cradle of the 1997 Regal was ground for clearance. Now that the cradle needs to be replaced I am looking at swapping in an aluminum one from a 00-03 Monte/impala, what else would I need besides just the cradle? Motor mounts etc?
    1997 Regal GS, L26 N/A block, 'Reptile' Ported Gen 3 Blower w/3.5 pulley, VS cam, K&N Open Cone, Speed Daddy Headers, 3" cat and res, Dual 2.5" Dynomax mufflers w/C6 Corvette tips. PLX Wideband, Custom Dyno Tuned By Jeff @ Engineered Performance. Lucerne 17's, F-Body Brakes.
  2. #2 Re: Aluminum cradle swap question
    Feb 2013
    37.295091, -121.930053
    hope you do a build thread again nice work on the fiero
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Aluminum cradle swap question
    Oct 2012
    West Branch, MI
    I have insurance and the car was not declared totaled, so a shop will be doing all the work... They did say that there repairs come with a 3 year/36k warrantee though. So probably no build thread pics ;( I will do another 3800 build sometime though
  4. #4 Re: Aluminum cradle swap question
    Feb 2013
    WAHOOOO lol
  5. #5 Re: Aluminum cradle swap question
    Should swap out no problem
  6. #6 Re: Aluminum cradle swap question
    Oct 2012
    West Branch, MI
    I heard about a wishbone mount? Or something like that.. Different for the L26 block? Can't seem to find the info I need. Maybe I just suck at searching.
  7. #7 Re: Aluminum cradle swap question
    If you have the aluminum oil pan it should be a straight swap I'm thinking.
  8. #8 Re: Aluminum cradle swap question
    It's a straight swap. I did however add 1/2" of spacers to the top and bottom of the engine mount only. The pass side looked a little low to me after the swap. One other thing, on my 2000 GS the power steering cooling section of the line hangs down and cips on the steel from between the mount bucket and the rear of the frame. The aluminum frame has a solid piece there. I allowed the line to sit in that flat area for the last 3 years and 60,000 miles. I've checked it a few times and planned to go with the police package (impala) 91c front mount cooler if it ever showed signs of wearing etc. So far..it looks good.
    Have you thought about the rear suspension?
  9. #9 Re: Aluminum cradle swap question
    Oct 2012
    West Branch, MI
    The way the car hit the curb only the front right went over it. Insurance is only covering the damaged parts so sadly the rear will remain stock, thank ou for the info Bill!
  10. #10 Re: Aluminum cradle swap question
    Np.. need morepics..just hit my pb account.
  1. Aluminum cradle and firmer bushing swap
    By buford1972 in forum Brakes/Suspension/Chassis
    Last Post: 01-21-2013, 11:43 PM
  2. trans swap cradle bolt retainer clip broken
    By 98regal in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2012, 01:29 PM
  3. W-body engine/tranny/cradle swap
    By gtpstyl in forum General Tech Discussion
    Last Post: 09-25-2012, 06:45 AM
  4. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
