Sabrewings
Yes... it sits still any time it is closed (which is during the entire warm up cycle, which is what my post was referring to). This is with the exception of the small amount routed to the heater core. Once you've hit your warm up temp, the tstat can settle at a partially open position to keep the temperature constant for the load. Going down the highway it isn't constantly opening and closing.
And, the coolant in the radiator doesn't move until you first hit operating temp. Don't believe me? Hold the upper radiator hose. It will stay ice cold on a winter morning until the tstat hits operating temp then you will feel a rush of extremely hot coolant. Every vehicle I've owned or worked on has done this (dead give away on when it's good to bleed). There are tons of reports in northern Canada where they're recommended to run a small hole in their tstat to gently warm the radiator coolant prior to the opening of the tsat. Yes, engine damages have been reported from this happening.
Ever looked at specifically how coolant is routed through the engine? The heater core is somewhat "parallel" to the radiator. It has one hose on the higher pressure side of the pump and one on the lower pressure side. It can pick up enough heat during the warm up cycle to give you heat. But overall most of the coolant in the engine is at a stand still. Yes the pump is pumping but due to its design (centrifugal veins) it can pump against a near solid wall of water without caring.
The entire time you're driving before you hit your operating temp your radiator coolant is just sitting, the same as most of the coolant in the block. Once that tstat finally opens (yes, it does seal 100%) then it starts to displace the hot coolant in the block. This is where you get cracked blocks from sudden temperature changes. If the car was flowing coolant through the radiator the entire time, then drilling it should have little to no effect and I can tell you it has a major effect on warmup time. Simply due to having to heat a lot more coolant during the warm up cycle, and having to keep it warm if you're driving.
And running without a tstat would never have the "-15*F coolant meeting 250+*F parts" effect because all the coolant would heat evenly because none would be isolated (either in the radiator or in the block).
I think you're under the impression when the tstat is closed there is still some flow to the radiator with the stock tstat. This is simply not the case, and is why we have drilled tstats in the first place (to prevent heat soak on parts like the heads which can lead to knock). I've already seen a drop in knock with a stock temp tstat but drilled due to the heads remaining at the intended coolant temp and not getting too hot during the warm up cycle.
Here's more info for you, from Wizbang:
