Thread: Intermediate Steering shaft replacement. Help needed.
Results 1 to 19 of 19
  1. #1 Intermediate Steering shaft replacement. Help needed.
    GT Level Member glendayle's Avatar
    Salt Lake City
    So went out to go for a drive and no steering. It appears that I disconnected the lower connection of the intermediate steering shaft. For those of you that have done this repair, what was necessary to do it. I can't seem to gain enough access room to reconnect it. Think of disconnecting the tie rod ends, disconnecting the rack from cradle and lowering the cradle. Any tips/advice welcomed.
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  2. #2 Re: Intermediate Steering shaft replacement. Help needed.
    Jack and support driverside. Pull wheel. Push boot up and undo 11mm on rack where it connects
    Pull boot out and put pieces back together, tighten the worlds smallest screw to hold it together.
    Slide boot back on and then reconnect to rack..might need someone to wiggle wheel slightly for it to pop on Put 11 back in.
  3. #3 Re: Intermediate Steering shaft replacement. Help needed.
    lower the rear of the sub frame, lift that damn boot as far up as you can so your hand can fit in there, wheels straight, and the steering wheel straight, pull the shaft down to the rack, lay it on the nub there, have a friend wiggle the steering wheel back and fourth till it lines up and slides on. its a snug fit. i used a long screwdriver to help push it the rest of the way on once it was on a bit. ( put it through the U joint at the end) spreading the end a bit does help, but dont spread it to much.
    if the bolt is still in the shaft, take it out. 12 inches of extensions will get a socket to it. the bolt is 11 mm iirc
    ive done this 2 times so far, it sucks. first time it slid right back on, second time the fight was on. as most seem to say.
  4. #4 Re: Intermediate Steering shaft replacement. Help needed.
    Salt Lake City
    Thanks, Sounds like it's just tough. I have the wheel off and I can push the boot back a little bit, but I just can't get my hands and arms in there very well. I'll grab a friend and mess with it when I get back from NJ.
  5. #5 Re: Intermediate Steering shaft replacement. Help needed.
    bill and i were talking in the chat, not sure if the shaft came apart on you or not, if it came apart, you may just want to change it. it should slide back together but its not supposed to come apart. theres a locking screw or rivet that hold the shaft from separating.
  6. #6 Re: Intermediate Steering shaft replacement. Help needed.
    Salt Lake City
    I believe the end of the ISS just slid off of the rack. I lowered the cradle quite a bit to get my cam in and I did not disconnect the rack from the subframe when doing this. I can't get a great look, but I had the boot partially pushed back and looks to be disconnected here. IF I get in there and see that the ISS has come apart itself, I will just replace the whole ISS.
    Thanks
  7. #7 Re: Intermediate Steering shaft replacement. Help needed.
    I live here. DirtDog's Avatar
    Jun 2012
    If u do replace it u should take tons of pics and do a write up
  8. #8 Re: Intermediate Steering shaft replacement. Help needed.
    problem with pics is, its so tight, most of the work is by "feel" you can hardly see what your doing.
    its pretty simple tho, ( on paper lol ) unbolt the shaft from the column from inside the car, as well as off the rack and pull it out, the fight starts when installing the new one.
  9. #9 Re: Intermediate Steering shaft replacement. Help needed.
    Jun 2012
    No steering wheel removal or anything else required? I wanna try to figure out omit my ISS is bad causing my steering wheel only wobble
  10. #10 Re: Intermediate Steering shaft replacement. Help needed.
    nope, its under the dash, in that damn boot/tube the shaft lives in. both sides of the boot is tight, and dont bend much, its rather rigged. i came close to just cutting it but thought better.
  11. #11 Re: Intermediate Steering shaft replacement. Help needed.
    Jun 2012
    Is there a way to test to see if its bad?
    OP sorry to thread jack
  12. #12 Re: Intermediate Steering shaft replacement. Help needed.
    id try greasing it, if it stops clicking its on its way out. you take white lithium grease in a spray can. with the tube. you want to spray in the hole under the U joint where it bolts to the column, this will spray the grease into the siding part of the shaft and lube it. see a post where a guy used vac line i think to extend the spray tube to make life easy.
  13. #13 Re: Intermediate Steering shaft replacement. Help needed.
    Jun 2012
    Could the ISS cause a wobble if bad? And I don't have a clicking noise. But it appears my wobble may just be in my steering wheel or rack.
  14. #14 Re: Intermediate Steering shaft replacement. Help needed.
    http://www.colinkraft.com/shaft.php heres a how too.
    it wont cause the wobble your dealing with, at least i dont think it could.
  15. #15 Re: Intermediate Steering shaft replacement. Help needed.
    Jun 2012
    ok. i looked at that and read through the gm manuals and it dont look like i need to pull the rack. but i think i will anyways and replace it to since its still got that annoying leak
  16. #16 Re: Intermediate Steering shaft replacement. Help needed.
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Be careful not to spin the steering wheel while the shaft is not connected or you will damage the clockspring. If your airbag light comes on after you get everything back together it will need replacing.
  17. #17 Re: Intermediate Steering shaft replacement. Help needed.
    ^^ this for sure. Sorry I didn't mention it.
    Follow what I wrote you. Get the 11mm off, then you can pull the boot out and reconnect that shaft ends. Put the boot back in and rehook to the rack.
  18. #18 Re: Intermediate Steering shaft replacement. Help needed.
    Salt Lake City
    Hmm. Thanks for telling me in advance guys, I may or may not have already done this
    Sent from my HTCONE using Tapatalk 2
  19. #19 Re: Intermediate Steering shaft replacement. Help needed.
    You'll know for sure if the steering wheel controls don't work and the air bag light is on.
  1. intermediate steering shaft
    By mstowe in forum Shops and Community Heroes
    Last Post: 10-08-2013, 07:02 PM
  2. [?] steering column plastic / intermediate steering shaft question
    By localhost127 in forum General Tech Discussion
    Last Post: 06-10-2013, 08:33 PM
  3. Intermediate steering shaft
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 05-23-2013, 12:22 PM
  4. Intermediate drive shaft (Jackshaft) needed.
    By ricksmastermix in forum Shops and Community Heroes
    Last Post: 11-25-2012, 01:42 PM
  5. Intermediate steering shaft?
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 07:30 PM
