Thread: Gen III or Gen V...? I'm in the middle and need advise
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    Hey guys, I'm about to get my top swap done. I'm at a point where I will incur minimal cost to use a Gen V. Right now I have a P&P ZZP Gen III with an accompanying S2 IC/S2 FMHE under my bed waiting. I am patient so time is not a factor for me as far as the overall build goes.
    My question is "is the switch from a P&P'd/IC'd Gen III to a Gen V (no IC yet) worth it, not just the short game, long term too." Pros and cons welcome.
    TIA,
    Slim
  2. #2 Re: Gen III or Gen V...? I'm in the middle and need advise
    ic gen 3
  3. #3 Re: Gen III or Gen V...? I'm in the middle and need advise
    Or you could use the ic on the gen v
  4. #4 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    Its a Gen 3 core, I was thinking I'd have to switch cores. Is there a way to mod it reliably? I'd rather even do that! How?!
  5. #5 Re: Gen III or Gen V...? I'm in the middle and need advise
    You can just throw it on there. Plenty of people do it
  6. #6 Re: Gen III or Gen V...? I'm in the middle and need advise
    Oct 2012
    West Springfield
    You'll be better off just sticking with the GenIII.
    From the sound of it, you don't even have a cam.
  7. #7 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    I have rockers to float me until its cam'd next year. A list of mods may help I guess.
    YT 1.9 for the mean time, k&n, LQ4 MAF, N* TB, P&P Gen 3 blower (thinking of converting to a 5), ZZP modified fuel rails, 60# FI, S2IC, S2 FMHE, P&P LIM, P&P heads (comp cam locks, viton seals, SS valves, 1.9" enlarged intake valve), LS7 lifters, ZZP SS headers, 3" catless DP, oil volume kit, alt rewire, voltage booster (S2), fuel pump rewire. I think that is it.
    I'm still debating a VS cam, XPZ cam, or the Intense S1X cam. That would be about a year out. This project has taken awhile to get together but I'm ready to get rolling. Hope that helps.
  8. #8 Re: Gen III or Gen V...? I'm in the middle and need advise
    plan for the cam sooner if your patient like you said. cause you may need head work depending on what cam you use, going big will need some work done.
    and why go and tear the lim off 2 times when you can do it all when your down to a stripped block? i vote save up for the cam, sell the rockers. install cam at time of top swap. get it tuned. and your done with tearing into it.
  9. #9 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    That was my first thought but I'm not decided yet (may never). As far as a "big" cam, not going to happen, this is a DD.
    Back on subject, P&P Gen 3 or Gen 5? I'll look more into using the IC on the Gen 5. Anyone know if the bolt pattern is the same? I assumed it was different, and that's why I assumed I couldn't use the gen 3 core on a gen 5 blower.
  10. #10 Re: Gen III or Gen V...? I'm in the middle and need advise
    They bolt up the exact same. You'll need one different bolt and the gen 5 opening is a little bigger on the passenger side.
  11. #11 Re: Gen III or Gen V...? I'm in the middle and need advise
    if you have the option go with the genV hands down. All in all its just going to be better for you in the long run and bolts right up to a genIII IC core (trust me, Id know). The fact that you dont have a cam in it yet is simply irrelevant, especially if you plan on doing it eventually...
  12. #12 Re: Gen III or Gen V...? I'm in the middle and need advise
    Minnesota
    I would do the Gen V get an IC from the guy on here who makes them. I have both and no cam.
  13. #13 Re: Gen III or Gen V...? I'm in the middle and need advise
    Oct 2012
    West Springfield
    Superb write up/comparison of the two superchargers over on CGP.
    Read that and decide for yourself if it's worth it for you.
    ClubGP Message Forum troubleshooting
  14. #14 Re: Gen III or Gen V...? I'm in the middle and need advise
    Minnesota
    Quote Originally Posted by Phil99gp View Post
    I would take the information in that thread with a HUGE grain of salt. The OP is a self proclaimed expert in just about everything.
  15. #15 Re: Gen III or Gen V...? I'm in the middle and need advise
    Plus... non of that info is really new.... ( I do like how he bashes Nicks modding thread though lol ) But, given the OPs mod list, he will more than likely be sub 3.0 on that genV where he WILL see the gains. Also, (unless I missed it) there is no mention of the much improved inlet of the genV to the genIII which will come into play at those pulley sizes aswell.
  16. #16 Re: Gen III or Gen V...? I'm in the middle and need advise
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    ^^^ Exactly!!! IF you do not plan on running a 3.0 pulley or smaller, stick with what you have. Gen V's open up with smaller pulleys..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  17. #17 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    I was thinking I would break it in with a 3.6 for a thousand miles ish, use a 3.0 until I feel like I want/need a 2.8. I forgot to mention but I'll likely (90% sure) be running E85.
    If knock free, 2.8, here I come!
  18. #18 Re: Gen III or Gen V...? I'm in the middle and need advise
    gardner,mass
    If you can get the genv for nothing go for it. If your paying more than 200 bucks for it, spend that money on an xp.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  19. #19 Re: Gen III or Gen V...? I'm in the middle and need advise
    gardner,mass
    Hi snowflake
  20. #20 Re: Gen III or Gen V...? I'm in the middle and need advise
    May 2012
    Albuquerque, NM
    For you guys running the gen 3 IC and gen 5 blower, did you have any hood clearance issues or is that l32 specific?
  1. 04 GP Temp gauge gets 1 notch over the middle? also loss of acceleration?
    By Joseph27705 in forum General Grand Prix Discussion
    Last Post: 07-08-2012, 10:10 AM
  2. middle east wi people
    By Hawkman in forum Midwest
    Last Post: 03-14-2012, 06:00 PM
  3. The display in the middle on a 1998 GTP
    By shawnz90 in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2010, 10:14 PM
  4. YAY middle class F*CKED again !!
    By 16MustangVet in forum Off Topic Discussion
    Last Post: 09-15-2010, 01:07 PM
  5. Transmission Coolers for the Middle East
    By Panzer4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 07:49 PM
