Thread: Plz help ASAP
Results 1 to 8 of 8
  1. #1 Plz help ASAP
    Nov 2011
    indiana
    Ok guys this is freakish weird I'm driving along all of a sudden dash lights go bazerk, engine wants to die rev up and it acts ok, little bit more lights dim and dash lights and mph and rpm gauges go crazy I am stumped and frustrated. Then sitting park running engine goes hay wire sucking air like no tomorrow, spit sputters it smooths out and then does it again and dies I have been HAVEING a problem with my battery when I shut car off it won't start per dead battery would all these problems b linked to the battery never had these issues until bat issue but I wanted to see if anyone else had any problems like this...
  2. #2 Re: Plz help ASAP
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Fix the obvious problem first.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: Plz help ASAP
    get the battery tested, as well as the alt. if one tests bad change it. clean the cable terminals up good, and check your grounds on the trans, should be 3 wires there.
  4. #4 Re: Plz help ASAP
    The dark side of the Moon
    Sounds like the alt is on it's way out, but do what scotty says.
    2004 Cobra
    2011 Mustang GT
    2013 F150 SCrew 5.0
  5. #5 Re: Plz help ASAP
    Nov 2011
    indiana
    Ok guys I will check everything tomorrow and report back an an odd thing I have since I bought the car is even with factory stereo there's a engine whine coming through the speakers
  6. #6 Re: Plz help ASAP
    thats a bad ground, either the body to battery, or the trans, or the radio's ground its self is bad.
  7. #7 Re: Plz help ASAP
    Nov 2011
    indiana
    Well I did find a loose ground on the trans by the starter battery is toast so I'm getting ready to go get m other from my house and toss it in and see how it goes thanks guys
  8. #8 Re: Plz help ASAP
    Nov 2011
    indiana
    New battery in no more crazy crap lol and fixed loose ground
  1. Need Help ASAP! Please.
    By Grand PrE in forum Off Topic Discussion
    Last Post: 06-03-2011, 02:04 PM
  2. need help ASAP !!!!
    By luk909 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2011, 01:12 AM
  3. 8 rib help! asap please!
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2009, 05:40 PM
  4. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
