Thread: need help ASAP !!!!
Results 1 to 20 of 21
  1. #1 need help ASAP !!!!
    Michigan
    I have a 2002 grand prix gt thats been driving fine until 2 day ago, i drove to work with no problem, car started fine, drove great, no smell or smoke. The only thing that I had was an oil change coming up which i was gonna do the next day. When i got out of work that same day my car wouldnt start, i checked the oil and was a quart low, I noticed alot of condensation on the inside of the oil cap, i put in a quart ad tried to start it, car started when i stomped on the gas, car was misfiring, running very rough and a ton of smoke pouring out the exhaust. I took off the intake manifold and found oil in the upper portion, changed the LIM gaskets, cleaned it out, changed plugs, wires, oil. Ther was NO coolant in the oil. someone suggested hydrolock. Car wont start unless the MAF is unplugged, white smoke pouring out of exhaust, as soon as its pluged in car shuts off and wont start, if it does start by chance, it runs rough and stalls out then it wont even try start........... I have ran out of ideas, need help. Like i said before the ran perfect until i got out of work
  2. #2 Re: need help ASAP !!!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    replace the maf, or clean it and give it a shot.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: need help ASAP !!!!
    Please pull the plugs and read them. Is one different than the rest. Unplugging the maf to start it typically means you have either a bad maf or a fuel/air problem.
    I'm thinking the first things you check are.
    MAF
    Injector
    Fuel pressure
  4. #4 Re: need help ASAP !!!!
    Michigan
    plugs are pre gapped to specs, but i checked them to make sure. when my car was finally towed before i started the work, i tried to start it and it made a loud poof sound and exhaust started pouring out of the engine bay, that why i thought it was the intake manifold because it looked like the exhaust was pouring out of that area. The only codes it read was for maf when it was unplugged other then that...... nothing.
  5. #5 Re: need help ASAP !!!!
    Michigan
    alright, changed the maf sensor and car starts up great but wont go past 3000rpm when reving up, itll bog and sputter and i give it more gas
  6. #6 Re: need help ASAP !!!!
    when you say revving it up are you in neutral or park? you could be hitting the rev limiter, does it bog when in drive going down the road when you floor it?
  7. #7 Re: need help ASAP !!!!
    Michigan
    when im in park it wont go past 3000rpm, but when im driving it, it will bog down when given gas and wont go past 3000 rpms
  8. #8 Re: need help ASAP !!!!
    St. Louis
    Could be fuel pressue, or a clogged cat. Has the fuel filter been changed?
  9. #9 Re: need help ASAP !!!!
    One more time... plug the f'n plugs and tell us which cylinder looks different than the rest.
    You don't do that.. It's tough love time.
  10. #10 Re: need help ASAP !!!!
    Michigan
    last time I knew I wasnt your kid, with all respect if I want rude feed back Ill go someplace else.
    Like i said before plugs were pulled and changed because they all looked like crap, new plugs put in, maf changed, car starts and idles great but wont go past 3000rpms. no misfire, no codes, plugs pulled again they look fine
  11. #11 Re: need help ASAP !!!!
    Sorry I read what you wrote as , "yeah I checked the gap".
    Next up is probably looking at the cat. Any rotten egg smells or rattling from underneath?
  12. #12 Re: need help ASAP !!!!
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    vac line.... do I win?
  13. #13 Re: need help ASAP !!!!
    Michigan
    No ratteling, or rotten smell, I'm starting to think a vac line or another sensor, would a bad map sensor cause it to not rev up past 3000rpm? Or I connected the wrong harness to the wrong sensor, damn this is frustrating.
  14. #14 Re: need help ASAP !!!!
    Michigan
    Took map sensor off, (well it came off in 2 parts) and there's oil inside of it
  15. #15 Re: need help ASAP !!!!
    Michigan
    Changed map sensor, car won't go over 20mph, bogs and acts like it wants to misfire, pulled plugs again, this time they had alot of carbon on them, when I play with the throttle under the hood there is a sound of suction when I increase the throttle fairly quick, could this be a vac leak or what? I can't tell where it's coming from but it sounds closer to the throttle body
  16. #16 Re: need help ASAP !!!!
    Hagerstown,Md
    Sounds like a Vac leak, SOmething that bad would toss a Lean bank code though. Pull the line off the top of the Fuel pressure regulator and see if gass comes out while at a idle
  17. #17 Re: need help ASAP !!!!
    St. Louis
    Replace the MAP sensor and go from there. Also replace the PCV valve if you haven't already. Be sure that you have 2 o-rings where your PCV valve sits in the UIM. IIRC, there should be one around the metal body of the PCV valve itself, and then a larger one in the UIM itself where the MAP sensor housing twists onto it. Should also be a spring on top of the PCV between the top. That would cause a massive vac leak right there.
    When my MAP was separating and causing a leak I never got a code for it. I just had a horrible idle and had to 2-foot it to keep it running in drive at idle (stop lights, etc...).
    The suction sound when you rap on the throttle sounds normal. You will hear some suction as the air is pulled into the motor. If you suspect a vac. leak in that area then with it idling spray carb cleaner around the TB area and see if the idle changes. If you find a spot that makes the motor change it's tone then that is a vac. leak.
  18. #18 Re: need help ASAP !!!!
    Michigan
    Great thanks, I'll try those ideas tomorrow, working on this car threw my back out and I think I'm fried.
  19. #19 Re: need help ASAP !!!!
    St. Louis
    good luck.
    I know the feeling, I just spent 12 solid hours working on my GT today. My shoulders are shot.
  20. #20 Re: need help ASAP !!!!
    Michigan
    Problem solved, thanks guys for your help and support. Apparently when the LIM gasket failed it pushed oil and coolant through the exhaust covering the o2 sensor, I managed to fry my maf sensor and the map sensor was covered in oil, i changed those and then had to unplug the o2 sensor drive it around the block to get the temp up, once that happened, plugged the o2 sensor back in and it drove great, sorry for getting snappy with some, but I think we all know how working on a car for a period of time can get to us, thanks again.
  1. New Here, needs help asap
    By holt149 in forum Introductions/Noob Questions
    Last Post: 02-20-2011, 08:01 PM
  2. 8 rib help! asap please!
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2009, 05:40 PM
  3. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
