Thread: Need my exhaust replaced - Grand Prix GTP 2001
Results 1 to 3 of 3
  1. #1 Need my exhaust replaced - Grand Prix GTP 2001
    Jun 2013
    Upstate NY
    I recently got an oil change at Monro and they told me I need from the catalytic converter on back replaced.. There is visible holes in both mufflers and the catalytic converter is leaking.
    To save money I would like to order the parts from Advanced Auto and take advantage of their $40 off $110 promotion currently running and then have a local shop install them.
    I'm just not sure what I need to buy.. any help?
    Thank you
  2. #2 Re: Need my exhaust replaced - Grand Prix GTP 2001
    Honestly...
    I'd buy a bolt-in downpipe from ZZP (you can get a catted 3" downpipe, you'll increase MPG's and performance as well for cheap)...get a $30 glasspack for a replacement resonator...and buy whatever mufflers you want. Dynomax Super Turbo's or Walker Quiet Flows are dirt cheap and quiet as hell.
    You can use the stock tips too if you want or get some cheapos off ebay. Again, up to you and your budget. Getting all of those things should keep your catback in check for quite some time. Not to mention sound a bit better since stock mufflers sound awful. So, you'd be out a few hundred bucks...OR, just buy an entire catback from ZZPerformance...and install yourself...but that doesn't come with the downpipe...so it'd be pricey.
  3. #3 Re: Need my exhaust replaced - Grand Prix GTP 2001
    you may want to make multiple purchases. mufflers are about 100 each, the cat in a DP is 200 easy, the res you can use a glass pack for 25 bucks, the Y pipe at the back from res to mufflers is around 120. these are all for walker parts.
  1. 2005 Pontiac Grand Prix GXP needs jump to start after trans replaced
    By Rkrajnov in forum General Tech Discussion
    Last Post: 03-21-2013, 07:26 PM
  2. 2001 grand prix
    By hoopdawg in forum General Grand Prix Discussion
    Last Post: 12-01-2012, 05:37 PM
  3. 2001 GTP - replaced transmission or stock?
    By OldFart in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2011, 11:50 AM
  4. is the 1999 grand am stereo the same as a 2001 grand prix gt?
    By llinziee in forum Audio, Security & Visual Electronics
    Last Post: 07-06-2011, 03:51 PM
  5. 2006 Grand Prix replaced Intermediate Shaft
    By Dennupe in forum General Tech Discussion
    Last Post: 12-02-2009, 09:22 PM
