Thread: Engine Ticking????
Page 4 of 4 FirstFirst ... 234
Results 61 to 77 of 77
  1. #61 Re: Engine Ticking????
    GT Level Member 2FASTGTP's Avatar
    Apr 2012
    Indiana
    Scottydogs, did you throw away the part of your gasket that broke off?
  2. #62 Re: Engine Ticking????
    i watch helplessly it as it fell into the front of the engine, never to be found.
    like i said, it leaked with out that part of the gasket under the snout, so i pulled that bolt, and smeared rtv all over it, it held for 2 years, and would have held longer.
    some cars leak, some dont from this area. it has no reason to leak, but mine did and a few other guys had the same issue, its rare.
  3. #63 Re: Engine Ticking????
    Apr 2012
    Indiana
    Lol thanks! I smeared the lim with rtv and will do the same with the bolt tommorow before i fill it up!!
  4. #64 Re: Engine Ticking????
    Apr 2012
    Indiana
    Just fired it up and drove it around my neighborhood with no leakage. Am i in the clear??
  5. #65 Re: Engine Ticking????
    Feb 2013
    37.295091, -121.930053
    just keep an eye on it. and look at the ground too
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #66 Re: Engine Ticking????
    Apr 2012
    Indiana
    Guess it didn't hold. It's going on craigslist now.
  7. #67 Re: Engine Ticking????
    what that bolt leak?
    if so just smear rtv all over it, then snug it back up.
  8. #68 Re: Engine Ticking????
    Apr 2012
    Indiana
    Scottydogs, it's getting damp around the bottom edges of the LIM.
  9. #69 Re: Engine Ticking????
    pics? is it clear oil?
  10. #70 Re: Engine Ticking????
    Apr 2012
    Indiana
    You wont be able to see from the pics. I took a QTip and wiped around the bottom edge of the lim and there was like some grayish color. I'm thinking it might not be leaking after all!
  11. #71 Re: Engine Ticking????
    check the fluid level, that will tell you if it leaking or not.
  12. #72 Re: Engine Ticking????
    Apr 2012
    Indiana
    I wiped around the lim after about 15 minutes of driving. It was kinda slimy but I wiped it off and this is all there was.
  13. #73 Re: Engine Ticking????
    if you spray brake cleaner all over, it will get rid of any oil residue, check the fluid level, if its full still drive it some more, then see if any oil forms around the snout on the lim.
  14. #74 Re: Engine Ticking????
    Apr 2012
    Indiana
    Ok I'll try the brake cleaner. I've wiped it with a napkin twice and it seems to stay slick so ill try that when I get home. I'm not gonna worry about it even if its a slow leak.
  15. #75 Re: Engine Ticking????
    Apr 2012
    Indiana
    Latest on the leak: if its leaking at all, it's very very slow. The supercharger plug is stripped so I can't check the oil level in it. Any way to get that plug out?
  16. #76 Re: Engine Ticking????
    mine was a torx, not a allen like most are. but it also stripped out, so i used a screw driver tapped into what was left of the allen or torx.
  17. #77 Re: Engine Ticking????
    Apr 2012
    Indiana
    Yeah mines a torx and the driver just ground it into shreds. Ill try a flathead, thanks
  1. ticking noise from engine
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2011, 05:53 AM
  2. Engine Ticking
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2011, 12:49 AM
  3. Engine ticking sound
    By zildjian102 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:24 AM
  4. Ticking in the engine....
    By fortune4you in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-01-2010, 09:59 AM
  5. i need help! engine ticking?? 3800
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 03:45 PM
