Thread: Porting heads....
Results 1 to 20 of 21
  1. #1 Porting heads....
    The Boss Iceman6669's Avatar
    Jun 2011
    So I recently aquired myself a set of stock L67 heads that I am going to clean up and attempt to port and polish. I have done lots of reading and seen lots of pics. I just figured I would start this thread so as if anyone has any pointers or advice I can learn it BEFORE I make a mistake...
    2011 F-150 Yote powered
  2. #2 Re: Porting heads....
    Feb 2013
    37.295091, -121.930053
    1 st one is wanting to lol jk, But really good luck with that
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Porting heads....
    Jun 2011
    Also what tools did you use. IE what bits and such. I know that using a die grinder will be much better then a dremmel.
  4. #4 Re: Porting heads....
    Eastwood porting kit.
    Be aware of the shaft position at all times.
    Be careful around the seat and the guide. Unless you're having new ones installed.
  5. #5 Re: Porting heads....
    HUDSON
    Dremel works great but get the flexible extension, it allows you to get into the ports well. For street heads, you don't want to change shape of ports, but rather clean them up getting rid of casting flash, pay most attention to the valve "bowls", blending and smoothing is what you want to do. Polish the combustion chamber completely, not mirror smooth, but clean and smooth to avoid hot spots, this is the biggest deterrent to "knock", important on Supercharged engines. Get all the little Dremel rotary files you can along with the sanding barrels and flapper wheels. Wear a dust mask too.
  6. #6 Re: Porting heads....
    May 2008
    Schuyler, NE
    Dremel's are for arts and crafts.
    Get a die grinder. If you don't have a good air compressor, look into something like this.
    Flex Shaft Hanging Motor Kit Complete Handpiece Variable Foot Control Dual Stand | eBay
    As said, make sure you retain the "D" shape exhaust port.
  7. #7 Re: Porting heads....
    Perfect time to buy a rotozip with flex shaft. Should have enough kick to do it.
    Step 1, have the heads cleaned and magnafluxed. If they fail fluxing..you can stop there.
  8. #8 Re: Porting heads....
    Jun 2011
    Yea... I m pretty sure I can flux them at work..
  9. #9 Re: Porting heads....
    Jun 2011
    Have any of you ever had heads decked? If so how much do you take off?
  10. #10 Re: Porting heads....
    May 2008
    Schuyler, NE
    It's a good idea to get it done. Take off as little as possible to get them flat. If you need to take off anymore than .025", I would recommend finding a different set of heads, or you might have problems keeping headgaskets from popping out.
  11. #11 Re: Porting heads....
    Jun 2011
    Well I was going to attempt it myself on a mill... And honestly I was doing it because someone told me it would boost compression... I was also planning on running thinner head gaskets..,
  12. #12 Re: Porting heads....
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    It's a good idea to have them tured up to make sure they are flat and smooth. Decking, I'd be leary about on these motors.
    And along with the Eastwood or Mr Gasket porting kit, get a good set or carbide bits also along with some buffs...
    I ordered this kit for mine along with a set of carbide bits off amazon, the buffs give your ports that shine..
    Standard Abrasives, Deluxe Head Port & Polishing Kit - Competition Products
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  13. #13 Re: Porting heads....
    Jun 2011
    So after long thought, I don't think I will deck the heads.... WAY too critical. Put I was thinking I might spray the intake and exhaust runners and valve bowl with dyechem before I start so I can see how much I have taken off and where I haven't touched it at all.
  14. #14 Re: Porting heads....
    Grand Island, Nebraska
    The port is cast black/gray so when you hit it with a die grinder it will turn it into shiny metal, you wont have to worry about seeing what you ported. I would get some intake gaskets and gasket match the heads and then the intake manifold all to the same shape/size. I would save up and get a valve job done last because you will probably nick the valve seats if you are doing the bowls. Get some cone/curved stone bits to take out the casting marks and get the shape, then hit it with some sandpaper bits to smooth it out and finish it off with some kind of polishing bit.
    I've always heard the exhaust ports give the best gains on these heads, which is good because they are the easiest to reach
    have you seen the head porting guide on clubgp? if not go find it.
  15. #15 Re: Porting heads....
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    when i did my heads, i had them milled .005" and i am running .052" cometic 4 layer head gaskets. that is .010" thinner than stock.
    so a total of .015" thinner. no probs here.
    also i grinded out the casting in my exhaust ports and buffed the bowls. There was as much as a 1/4" stick out in the exhaust ports.
    Then finished up with a 3 angle valve job.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  16. #16 Re: Porting heads....
    Jun 2011
    Here is what my heads look like after MagnaFluxing them
    Porting heads.... Attached Images
  17. #17 Re: Porting heads....
    typical l67 head.
  18. #18 Re: Porting heads....
    Jun 2011
    Thats what I was thinking
  19. #19 Re: Porting heads....
    How far into the bowls do the cracks go?
  20. #20 Re: Porting heads....
    Jun 2011
    No farther then the seats from what I can tell.
  1. How much porting on heads??
    By Steven Monteith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2012, 06:48 AM
  2. Porting Series II Heads?
    By indygrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2012, 09:16 PM
  3. Porting l26 heads
    By jakewet28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-25-2011, 07:44 PM
  4. Porting heads
    By monsterjam5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2010, 10:34 PM
  5. porting heads
    By blowfishRus6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2009, 08:57 PM
