Thread: Coolant System Flush
Results 1 to 13 of 13
  1. #1 Coolant System Flush
    SE Level Member Alcatraz's Avatar
    May 2012
    United States
    I'd like to do a coolant system flush on my car since I haven't done one since I first got in over a year ago, and because my TEMP light started to come on today so I guess it's starting to overheat a little bit. I can't find a write-up on how to do it, could someone point me in the right direction? Thanks!
    "Trixie" Grand Prix <3 - Click Me!
    2000 Pontiac Grand Prix GTP Daytona 500 Edition
    Galaxy Silver
    Awesome
  2. #2 Re: Coolant System Flush
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Drain coolant via bleeder screw on bottom of radiator, fill with water from hose, start engine for 30 sec or so, drain, and repeat until water comes clear, then fill half with non dexcool (green is popular) and half distilled water. Temp light being on is probably not from not changing coolant though, not sure though. Someone will chime in.
  3. #3 Re: Coolant System Flush
    Feb 2013
    37.295091, -121.930053
    umm its called the drain cock (like what you call a roster). Also your directions leave tons of dexcool in it. you need to drain the raditor then leave the plug open and run water in it for about 10 mins. this will flush all the old coolant out and leave you with water in there. Next lets the water drain out then fill it back up with what ever you like. and don't for get to bleed the system of air.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Coolant System Flush
    London Ont, Canada
    that prestone flush stuff is handy if its got gummed up dex, its like a detergent.
    this video gives ya basics, nothing specific but its kinda handy
    if youre worried and not afraid to spend a few extra bucks, buy premix, but its almost fool proof,
    Bleeding is the key element, and it will bleed itself a little over first few days of driving.
    also take and maybe change the thermostat, and flush the lim seperately with water, same as heater core, dex loves to hide there.
  5. #5 Re: Coolant System Flush
    Feb 2013
    Woodbridge NJ
    I guess 02NavyBlue and I went to the same school for cooling system flushing. Typed at the same time too
    Don
  6. #6 Re: Coolant System Flush
    Dec 2012
    Where 4T65E's were born
    I remove both rad hoses, the lower gets removed from the rad, and the upper gets removed from the engine. I remove the thermostat and radiator cap. Then I flush the Radiator, engine block, and heater core separately with a garden hose on full blast for at least 30 seconds each way. Flushing, and back flushing. It's important to get all of the coolant out if you're switching from dex-cool to conventional. I did this and don't have a speck of brown sludge after the switch.
    Sold.
  7. #7 Re: Coolant System Flush
    Feb 2013
    Woodbridge NJ
    I did my sons car like this. Removed the lower radiator hoses from radiator. Removed the thermostat housing and kept it attached to the hose. Used a hose nozzle wrapped in a rag and inserted it into the intake where the thermostat sits. Ran water for several minutes. Reversed the flow by shooting the water through the lower hose so it came out the intake. Once it ran crystal clear I disconnected the heater hoses. Used a small nozzle and flushed the heater core and hoses going both directions. I then rinsed out the radiator same method, both directions, until crystal clear. put the lower hose back on the rad and added 1 gallon of 100% coolant. Then added 50/50 mix until it flowed out of intake. Installed new thermostat and closed it all up. Topped it off and bleed it out. Good to go
    Don
  8. #8 Re: Coolant System Flush
    Quote Originally Posted by Dadillac View Post
    Don
    this works well, but if you put the lower hose back on, leave the T stat out and the upper hose on the housing, and off the rad. put the hose in the rad, fill it up, then start the car, run it till clear water comes out the upper hose, then turn the hose off, then run the car till no water comes out the upper hose. turn it off. then put the T stat back, the upper hose back, then dump one gallon of straight antifreeze in the rad, start the car full the rest of the way with hose water.
    then idle the car rad cap off till the fans turn on, then bleed the air out of the t stat housing, top off the rad as needed as it warms up, if it burps and the rad level drops, the T stat opened up for a a few seconds and took the coolant, the cold water from the rad made it close again.
    waiting for the fans to come on means its hot enough that the T stat should be wide open.
    you can also pull the heater core hoses off the back of the engine, and flush it both ways with a garden hose. then put the hoses back on, but fill the hoses with water so no air gets trapped in the core.
  9. #9 Re: Coolant System Flush
    May 2012
    United States
    Okay I'm hearing you all talk about this, how do I flush the engine block and heater core?
    Galaxy Silver
    Awesome
  10. #10 Re: Coolant System Flush
    Feb 2013
    Woodbridge NJ
    Quote Originally Posted by Alcatraz View Post
    Use a water hose nozzle. Wrap a rag around it and insert it into the hose or intake. The rag forms a seal to force the water through the block.
    Don
  11. #11 Re: Coolant System Flush
    Feb 2013
    the one reserviation i have about premix is that it cost more i just get the pure stuff then mix it my self 2 one gallon jugs makes 4 gallons. and its half the price.
  12. #12 Re: Coolant System Flush
    Dec 2012
    I just bought 2 gallons of pure stuff and added it to my cooling system after the flush (engine block full of water). It's a 13-ish quart capacity, and I added 6 quarts of pure antifreeze. That's just about the 50/50 you want.
    And flushing with water using a hose is the way to go. Back flushing gets some more crud out and changing the t-stat restores the cooling system's efficiency.
    Sold.
  13. #13 Re: Coolant System Flush
    Feb 2013
    also a side note if you really feel up to the challenge of getting it perfect then you could (not saying you should) replace the radiator, heater core, and hoses to bring it back to perfect. but most don't because of cost and time.
  1. Cooling System Flush - most effective way
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2011, 05:03 PM
  2. Cooling system flush
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2010, 12:16 PM
  3. Coolant Flush?
    By gahris in forum General Tech Discussion
    Last Post: 04-03-2010, 02:12 PM
  4. Coolant Flush twice?
    By nyydmb12 in forum 04+ Specifics
    Last Post: 02-14-2010, 08:17 PM
  5. Coolant System Flush
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 08:59 PM
