Thread: Changing out intake manifold gaskets
Results 1 to 20 of 36
  1. #1 Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    Alright so im changing out the intake manifold gaskets and am unsure of what kit to get. Im doing both the upper and lower but it is hard for me to find a kit with both of them believe it or not. Should I just go to O'Rileys and order it from them or find a kit online for a better price? What brand should I stick with? Links would be great also!
    Edit: Sorry its a 2000 gtp!
  2. #2 Re: Changing out intake manifold gaskets
    Hi... we'd love to help out, we don't know which engine you have. Please give us your year and model. I have never seen a kit that had both upper and lower gaskets included unless it was a full engine rebuild kit.
  3. #3 Re: Changing out intake manifold gaskets
    Johnstown, NY
    He has a thread to fix his 00 gtp. I don't think they make a kit for both. I like to use rockauto for the cheap prices online. Just be sure you get the metal lower one.
  4. #4 Re: Changing out intake manifold gaskets
    Ahhh good to know. Thanks. I run from thread to thread fast enough that I'm not hunting.
  5. #5 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    Yea sorry about that its a 2000 gtp but I looked at rock auto and was only able to find the lowers but maybe I just wasnt looking hard enough haha
  6. #6 Re: Changing out intake manifold gaskets
    I live here. TLSheff's Avatar
    SEARCH "lim" (with " "s) or lower intake gasket. There are tons of threads on how to do it and what all you need. It's kind of a big issue with these cars, just make sure you get the felpro metal replacements or you will be doing it all over again in the future.
  7. #7 Re: Changing out intake manifold gaskets
    the super charge gasket is called a upper plenum gasket. they sell for 11 bucks on rock auto. check the shipping at check out, sometimes they ship from 2 warehouses, and the sipping kills you. they can be bought local for 12 bucks at autozone for a flepro gasket.
    the a/c delco metal gaskets were 42 bucks at rock auto. make sure you get the metal ones, not the plastic.
  8. #8 Re: Changing out intake manifold gaskets
    Scrap the quotes... just read this VVV
    http://www.grandprixforums.net/video...utes-3112.html
    This should cover about 99% of it.
  9. #9 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    Alright thats why I havent been able to find the upper!
  10. #10 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    Alright thank you so much for clearing that one up haha
  11. #11 Re: Changing out intake manifold gaskets
    Run a search at Rockauto for # 24503911. Should pull it up, that's the GM # for the supercharger gasket.
    Do not buy Garlock gasket, Felpro or GM only. Garleaks are known for leaks.
  12. #12 Re: Changing out intake manifold gaskets
    Quote Originally Posted by Drummer9103 View Post
    been there myself. went to buy one the guy had no clue what a super charger gasket was, not listed in the pc. so found it on ra listed as a upper plenum gasket, the double shipping made it cost 15 bucks, and i was doing my lim job on a tight budget, so i went back to auto zone with the proper name, and they had it in stock.
    i had 20 in rewards coming to me from AZ so i got the gasket and antifreeze for 5 bucks, whole job ran me 60 bucks out of pocket.
    the cheap intake gaskets dont come with much, tho. just the end rubber and metal gaskets. if you want new injector o rings and the tb gasket, and a the O rings for the coolant ports, (i went cheap) this is a more complete gasket set, they run around 70 tho. i had rtv, O rings, and thread sealant already for the lim bolts. so i needed very little more then the gaskets.
    pick up a set of elbows too. i took some channel locks, and just twisted and snapped the upper elbow. then installed a new upper with the intake.
    pic of snapped elbow.
  13. #13 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    http://www.rockauto.com/catalog/moreinfo.php?pk=260723 This the one? Also should I get new lower intake bolts? And do you suggest new injectors or just new o-rings?
  14. #14 Re: Changing out intake manifold gaskets
    your link sent me to the home page.
  15. #15 Re: Changing out intake manifold gaskets
    All the part numbes you'd likely want
    http://www.grandprixforums.net/commo...ets-39796.html
  16. #16 Re: Changing out intake manifold gaskets
    More Information for FEL-PRO MS95744 This the one? Also should I get new lower intake bolts? And do you suggest new injectors or just new o-rings?
    you can buy just new injector rings from rock auto, or at AZ, no need to buy new injectors, they cost a bunch. you re use the lim bolts. but do get some thread sealant for the threads of the lim bolts.
    watch that lim in 33 minutes vid, its shows a lot of good info.
  17. #17 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    Alright I just ended up gettin the lower intake gasket, upper plenum gasket, and o-rings at O'Rileys all Felpro and it ran me about 60, now all I have to do is get the coolant elbows
  18. #18 Re: Changing out intake manifold gaskets
    dont forget rtv if the kit dont come with it, thread sealant, and vac T's and some vac tubing, as those T's will break on you, its 100% probability they will crack.
    and one gallon of straight antifreeze.
    the fat vac line off the TB that loops to the back of the engine, it also likes to break. i used a fat line that fit the nipple on the TB, then the smaller one fit inside the fat one, then pushed it on the factory plastic line.
    i took the lower rad hose off the engine, propped it up so i saved what coolant was in the radiator. then took both dog bones off, then rocked the engine back and fourth till no more coolant came out the where the hose clamped on. then start taking it apart.
    when you pop the lower intake off, have the egr tube removed, the elbow broken off, then pop it up, once its free, lift it up and off as level as you can to keep what coolant maybe left in the lim. theres a lip that can hold a small amount inside it. if your careful, you wont spill any in the engine, and wont need to do a oil change. i was able to not spill any coolant, no oil change for me at the time of the lim job.
    some guys like to do 2 oil changes in a row with in hours of starting it up. just to be safe.
  19. #19 Re: Changing out intake manifold gaskets
    Aka 3/8" to a 3/8-1/4 reducer to a piece of 1/4" about 24 inches long.. presto.. no leak ever again.
  20. #20 Re: Changing out intake manifold gaskets
    Apr 2013
    Dayton OH
    It came with some rtv so im set with that, Thanks for the sizes too i will probably go to the dealership tomorrow to pick pick the elbows/T's up. Im probably gonna change the oil out anyways with my luck. haha
  1. How to tell if you have the GOOD Lower Intake Manifold gaskets.
    By bps02gtp in forum How To Write-Ups/Tech Tips
    Last Post: 08-15-2012, 07:38 AM
  2. Replies: 7
    Last Post: 12-25-2011, 08:02 PM
  3. Changing intake gaskets and a bolt is stripped
    By darkcherrymetallic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2011, 01:10 AM
  4. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  5. Intake manifold and VC gaskets...
    By bowsox88 in forum General Tech Discussion
    Last Post: 02-15-2011, 07:52 PM
