Thread: A/C dual control question
Results 1 to 5 of 5
  1. #1 A/C dual control question
    May 2012
    Jacksonville, Fl
    I have an 02 GP with dual temperature control. With both setting on cold, I get cool air out of the passengers side and warm out of the drivers side. Can anyone tell me what my problem is and what I need to repair or replace? Thanks in advance, Bill
  2. #2 Re: A/C dual control question
    Try looking into a blend door issue.
  3. #3 Re: A/C dual control question
    May 2012
    Jacksonville, Fl
    The air goes where I want it, ie, floor, floor and chest, defrost. The problem is the passenger side will blow cool but the drivers side will blow warm. If I move the slides up to hot then both sides blow hot. Just am not getting any cool or cold air out of the drivers side vents.
  4. #4 Re: A/C dual control question
    St. Louis
    The drivers side blend door actuator is shot. Been through this on an 03 Imp 2 times now. Have to lay on the drivers side floor and look up behind the dash along the airbox. You will see a small black box attached to the airbox with a small wire lead on it. Think its 2 or 3 screws. Remove wire, screws and pull the old one off. Take a look at the new one as the shaft it lines up with is flat on one side. Swap in the new one and test.
  5. #5 Re: A/C dual control question
    May 2012
    Jacksonville, Fl
    Quote Originally Posted by FordMan77 View Post
    Thank You very much FordMan. I have been busy the past few days but will climb under there within the next few days and hopefully find what your telling me and get it replaced. Bill
  1. Dual climate control question
    By Dennis47834 in forum General Tech Discussion
    Last Post: 08-08-2011, 10:28 PM
  2. what would i have to do to put dual climate control in my 99 gt gp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 12-15-2010, 09:20 PM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  5. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
