FordMan77
The drivers side blend door actuator is shot. Been through this on an 03 Imp 2 times now. Have to lay on the drivers side floor and look up behind the dash along the airbox. You will see a small black box attached to the airbox with a small wire lead on it. Think its 2 or 3 screws. Remove wire, screws and pull the old one off. Take a look at the new one as the shaft it lines up with is flat on one side. Swap in the new one and test.
