Thread: A/c blowing hot air
Results 1 to 20 of 20
  1. #1 A/c blowing hot air
    May 2013
    United States
    Hey guys my a/c is blowing hot air and i wanted too know what i could check too see if theres a leak or something. Its a 99 grand prix gtp. Its getting hot and im gonna need too know where too go with this
  2. #2 Re: A/c blowing hot air
    Cambridge, Ontario Canada
    Look for oil stains around the compressor & the AC lines, I think they also have coloured leak detector stuff you can inject into the AC line, then look for that colour to appear?
    2005 E55 - stock
  3. #3 Re: A/c blowing hot air
    May 2013
    United States
    Where do i find this stuff could you provide me with a pic or desribe where i look thanks
  4. #4 Re: A/c blowing hot air
    Grand Rapids, MI
    at any auto parts store they have the freon with dye or whatever.
  5. #5 Re: A/c blowing hot air
    Feb 2013
    37.295091, -121.930053
    good old UV die you also might want the glasses and light for it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  6. #6 Re: A/c blowing hot air
    May 2013
    United States
    Can i add freon my self?
  7. #7 Re: A/c blowing hot air
    Feb 2013
    you can just get the can that looks like this Interdynamics AF22 - R-134a Refrigerant | O'Reilly Auto Parts
    but dont over fill your system!!! or you may blow a line
  8. #8 Re: A/c blowing hot air
    St. Louis
    It may be worth the $$ to have a trained professional look at this issue. A/C isn't something I'd jump into without some knowledge, plus they can usually find the leak faster and tell you what it is, then you can fix it yourself.
  9. #9 Re: A/c blowing hot air
    May 2013
    United States
    And where do i put it at
  10. #10 Re: A/c blowing hot air
    Grand Rapids, MI
    the schrader valve on the a/c line.
  11. #11 Re: A/c blowing hot air
    Put it in your butt.
  12. #12 Re: A/c blowing hot air
    Feb 2013
    LOL
  13. #13 Re: A/c blowing hot air
    May 2013
    United States
    Quote Originally Posted by brandonl2000 View Post
    U just squirt it right in there?
  14. #14 Re: A/c blowing hot air
    No.
    Do some reading on how to actually fill the AC system.
    Gauging from what you type and how you answer questions, your skill level with cars is next to zero, it likely best to have a shop figure out whats wrong with your AC system.
    I bet there is a bigger problem than just being low on freon, because the AC system is a SEALED system that should NEVER lose any of the freon inside.
  15. #15 Re: A/c blowing hot air
    You need to excuse FFDP, he hasn't been laid in something like 5 years ...and he's pmsing too
  16. #16 Re: A/c blowing hot air
    Feb 2013
    love that ^^^^
  17. #17 Re: A/c blowing hot air
    I agree with Cam though (FFDP) from the sound of it, you are going to spend a lot of money trying to learn about AC and likely still do it wrong. A shop might be a lot cheaper in the long run.
  18. #18 Re: A/c blowing hot air
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    So if I were to by a refill kit, what is the max pressure to recharge the system to?
  19. #19 Re: A/c blowing hot air
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    read the gauge, im guessin blue for this one
    http://www.canadiantire.ca/AST/brows....jsp?locale=en
    i used this one and it worked well .
    http://www.redtek.com/techinfo.html
    heres how to do it,
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  20. #20 Re: A/c blowing hot air
    The thing here is..you don't know much w/o two gauges. One on the high and one on the low sides.
  1. AC not blowing air
    By Aopps in forum General Tech Discussion
    Last Post: 06-14-2012, 10:00 PM
  2. Blowing MAF fuse in an 01 3.1
    By NSGRAND in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-10-2012, 06:32 PM
  3. Why do i keep blowing this fuse?
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-04-2011, 09:01 PM
  4. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  5. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
