Never done a CV on a Grand Prix before, but I can tell you there is not near enough room to do it that way on the majority of cars.
To all who posted on this thread lesson learned... I got it on. And as far as reading more most all video's on youtube say to take off the ball joint. If I ever have to change it again I know. Thank you all for the help.. save me some money
All the people that remove the strut to knuckle bolts are rookies.
Its a breeze doing it the ball joint way when you actually know how to man handle a pry bar.
I have actually had really good luck on my car. The only two times I have had issues getting stuff apart was my stock tie rod ends (Would just spin when I tried to take the nut off so I just cut them off sincce I was changing them anyways) and the bolts between the cat back exhaust and the downpipe (Cut them off and drilled them out, sucked)
I'll spray some lube in there if it's tight. Not popping the balljoint is quicker.
FWIW though on you guys that do the strut to knuckle bolts, you need an aligment after doing that. Balljoint is a fixed position, no alignment needed. That's why most places do it that way.
Hey bill I did mine last month on drivers side. I took the strut to knuckle bolts off (bear in mind as we all know I'm a rookie) and didn't need an alignment.
Haha I did it on my passenger side over 5k miles ago and the wear is even on the directional tiresso I got lucky twice?
I do think so....just went and checked to see![]()
You went to an alignment shop just to check? You are dedicated
Your right I did....and guess what....it is fineI got it checked for free to
