Thread: leaking from where?
Results 1 to 20 of 21
  1. #1 leaking from where?
    Roseville, Michigan
    I was driving home today and my low coolant light came on, I looked under the car to find coolant dripping at a high rate from where the water pump is, I felt around the pump and it was dry and the belts are clean, the bypass elbow is not broken and no leaks from the hoses that I can see, it has a new radiator. Like I said its comeing from the bottom of the engine somewhere but can pin point it cause its dripping from the oil pan but staying on the passenger side of the car. Am I missing something or is there a wheeping hole on the water pump I should check? are there any other things Im missing here? This is a 97 gp gt with 152,000 miles 3.8 nonturbo nonsupercharged. can anyone point me in a direction befor I decide to spend thousands takeuing it to the dealer?
  2. #2 Re: leaking from where?
    The weep hole is on the bottom of the water pump i think. Might as well change the water pump and coolant elbows.
  3. #3 Re: leaking from where?
    Roseville, Michigan
    if it was weeping, would it be a lot that comes out or just a steady drip?
  4. #4 Re: leaking from where?
    Apr 2013
    Houston,Tx
    having the same problem but I already changed the water pump and it hasnt stopped
  5. #5 Re: leaking from where?
    Did you check the lower coolant elbow?
  6. #6 Re: leaking from where?
    Roseville, Michigan
    theres 2 elbows on this engine? I know of one, which I have replaced a million times. lol
  7. #7 Re: leaking from where?
    They come in a two pack, there are two.
  8. #8 Re: leaking from where?
    Roseville, Michigan
    Where is the lower one? I know they come in a two pack but thoight the other one was for some other car.
  9. #9 Re: leaking from where?
    Below your alternator tensioner is the other one. If you take off the alt tensioner to replace them, they are both there.
  10. #10 Re: leaking from where?
    Roseville, Michigan
    Ok thanks I'll look into.that. do.I have to take off anything else I have to remove to get to it? I know I have to remove the one on top that bypass manifold if that's what it is, but is thatother elbow attached to something I haveto remove. I don't want to run into an uhoh I broke this situation lol
  11. #11 Re: leaking from where?
    Pull the alternator. Pull the alternator bracket. Replace elbows. Put back together.
  12. #12 Re: leaking from where?
    Roseville, Michigan
    Ok thanks. I neeed to buy a chiltons book lol
  13. #13 Re: leaking from where?
    Actually you don't. Chiltons will tell you less than you currently know.
    Do an advanced search on the word "e asy" without the space and my screen name. Pull up the how to on changing coolant elbows. Has pictures of the actual parts
  14. #14 Re: leaking from where?
    Roseville, Michigan
    Sweet thanks for the info. I hope that's the problem
  15. #15 Re: leaking from where?
    Ps.. you know what to do the next time you are looking for a how to ...don'tcha?
  16. #16 Re: leaking from where?
    Roseville, Michigan
    I look around, maybe wrong keywoerds . I was out looking at it and there is fresh coolant underneath the belt tensioner so.I'm betting your right, that second tube you.get in the pkg is that one for that? Or do I buy a different tube? Yes u do know where to look lol I used to come here a lot when I had problems.
  17. #17 Re: leaking from where?
    Yeah..the second elbow is for that.. that's why it's there.
  18. #18 Re: leaking from where?
    Quote Originally Posted by greengt View Post
    do tell how you changed the top elbow and didnt know about the lower one?, the alt bracket has to come of to change them.
    if you drive a 97 or 98, you have a cast lowr elbow on the alt bracket, steal the large O ring off the new elbow, then put it on the cast elbow.
  19. #19 Re: leaking from where?
    I know a guy that pulled LIM's to do the elbow.
    Same guy banned me for being helpful.
  20. #20 Re: leaking from where?
    i changed only the upper when i changed my lim gaskets. theres only 2 ways to get the upper back in, alt bracket or lower intake has to come off lol
    some fool banned you? hes not very smart i guess lol
  1. Leaking on the top
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-24-2012, 07:23 AM
  2. Leaking
    By gtpzmdc in forum General Tech Discussion
    Last Post: 08-17-2012, 01:59 PM
  3. Leaking oil all under car
    By GTLGDP in forum General Tech Discussion
    Last Post: 01-17-2012, 08:15 AM
  4. leaking pan
    By tdm571 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-01-2011, 03:18 PM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
