Thread: 2000 Grand Prix Issues
Results 1 to 12 of 12
  1. #1 2000 Grand Prix Issues
    Apr 2013
    Calgary AB
    Well this is kind of puzzling? I have been having a shifting issue when I come to a stop and proceed to go I get a shudder and when under a load like pulling a long hill it seem like I really need to get on the gas to get it to go ( sliped this after noon ) Car has a whine I have ruled out pulley issues. Had the codes scanned and it came with a temp sensor and the dreaded O2 sensor code that I think may actually be an O2 sensor. I checked for vacuum leaks none I checked for a bad fuel regulator and it's dry. Also it won't idle correctly it's up around 1000 rpm and it will drop to about 400rpm studder like its going to stall but it revs it self up? Fuel mileage mixed is around 17 mpg mixed driving I was getting better from my suburban! Any help guys! I really like the car I don't want to be in the market for another car!
  2. #2 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Omaha, NE
    Fix the known problems first.
  3. #3 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    Quote Originally Posted by greengp2000 View Post
    well this is kind of puzzling? I have been having a shifting issue when i come to a stop and proceed to go i get a shudder and when under a load like pulling a long hill it seem like i really need to get on the gas to get it to go ( sliped this after noon ) car has a whine i have ruled out pulley issues. Had the codes scanned and it came with a temp sensor and the dreaded o2 sensor code that i think may actually be an o2 sensor. I checked for vacuum leaks none i checked for a bad fuel regulator and it's dry. Also it won't idle correctly it's up around 1000 rpm and it will drop to about 400rpm studder like its going to stall but it revs it self up? Fuel mileage mixed is around 17 mpg mixed driving i was getting better from my suburban! Any help guys! I really like the car i don't want to be in the market for another car!
    t.p.s. ???
    Top-Swapped GT, SLP headers, 3.2 Pulley, Stage 2 Intercooler
  4. #4 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Nov 2011
    NY
    You left out a lot of information... Model, mileage, recent maintenance if any, etc...
  5. #5 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Omaha, NE
    Quote Originally Posted by coolone View Post
    Based on the fact that there are known underlying issues, it's probably safe to assume that there hasn't been any recent maintnance.
  6. #6 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Apr 2013
    Calgary AB
    Thanks for the response it's a 2000 Pontiac grand prix gt 3.8 218,000km recent Maintanance oil changes every 5000k synthetic oil since new, transmission flush and filter, new brakes, tires, air filter, fuel filter, fuel pump, tentioner pulley, this car has been very very well maintained! All this work has been done under the last 5000km please do not assume that I don't take care of my car! There is no check engine light on and my car has thrown codes! I just got the parts to fix the two codes today and was wondering if anyone had the same issues.
  7. #7 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    What are the codes? Knowing that would help a lot
  8. #8 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Apr 2013
    Calgary AB
    The codes are P0128 temp sensor low and P0107 bank one lean
  9. #9 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Things like the temp sensor may be playing a part in the issue. I'd also suggest fixing the known issues. Small stuff like how the car runs can effect the trans greatly.
  10. #10 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Nov 2011
    NY
    No assumptions made, I asked to identify maybe something recently done going awry! : )
    As thought though, not all info. was provided... As Bill mentioned, clear the known problems, codes, etc. and likely the other issue may magically fix itself. Let us know how it goes and don't give up so easily (looking for another car) lol.
  11. #11 Re: 2000 Grand Prix Issues!!!! Please HELP!!!!!
    Apr 2013
    Calgary AB
    Ok I fixed the known issues no codes car is still running wired! Almost sounds like I have a miss fire ? New plugs and wires, mass air flow sensor is new! Some times when I start it it will rev up sputter then stall I have to put my foot on the gas and rev it up for a few seconds then it's fine very puzzling no codes or check engine light on? Any suggestions?
  12. #12 Re: 2000 Grand Prix Issues
    Unplug your mass airflow sensor.
    Which plugs and wires did you get?
    What did you do about your code P0107 (which I wonder..did you mean P0171?)
  1. 2000 Grand Prix Tachometer/Trac Light/Stall Issues
    By ZackN in forum General Tech Discussion
    Last Post: 09-26-2013, 11:40 AM
  2. 2000 pontiac grand prix gt sedan bronzemist color 2000 obo
    By wavedout33 in forum For Sale - Vehicles
    Last Post: 02-09-2013, 07:25 AM
  3. 2000 Grand Prix GT starting issues
    By Ponticaconfused in forum General Tech Discussion
    Last Post: 01-03-2013, 12:25 AM
  4. 97 grand prix issues
    By us Sgt in forum General Tech Discussion
    Last Post: 06-20-2011, 06:59 PM
  5. 2000 Grand Prix Electrical issues
    By Stappen720 in forum General Tech Discussion
    Last Post: 09-24-2009, 06:32 AM
