Thread: 2000 Grand Prix GT starting issues
Results 1 to 7 of 7
  1. #1 2000 Grand Prix GT starting issues
    May 2012
    kansas
    Hello,
    I have a 2000 Grand Prix GT with a 3800 seris II engine. Last week drove it to work and 6 hours later went to leave and it would not start. Engine will crank but not fire up. Towed it home. Started with the simple things. Spark---yes battery good---yes NO security light on dash---yes Problem....No Fuel !!! When the key is turned the fuel pump refuses to prime. Test the electrical contact at the pump....nothing at all. Went to the fuse...replaced the 15 amp fuse with a new one. Replaced the mirco relay with a new one......same results....no power at the fuel pump.
    Read through the web and found a test to see if the pump was bad or not so did it...test listed below :
    The all-important Jumper Test. If you do this, and the car runs, then you know that the fuel pump resistor is the culprit. Note: while the jumper is in place, your fuel pump will be running at high speed all the time. This puts great stress on the fuel pump. This is a temporary fix. In the case of this 1998 Grand Prix, the relay needed was #14. In some Grand Prixs, it will be #19. Obviously, if your car does not have a #19 relay, you can count on using the #14 relay. What's important is the number and orientation of the spades on the relay.
    If you look closely in the pic to the right, there is a red line connecting 2 out of the (5) slots. Place a small (16 AWG or smaller) short wire between these two slots as shown, and reinsert the relay to pin them down.
    Fuel pump turns on and runs but still can not get the car to start. Called the parts store and asked about the fuel pump resistor. They tell me the 2000 grand prix does not have one to replace.
    Can anyone tell me if they have had any of this problem and if I am missing something?
    Thanks
  2. #2 Re: 2000 Grand Prix GT starting issues
    Apr 2009
    Fort Worth TX
    98 GT may not even have a fuel pump resistor? Is yours a GT or a GTP?
    Edited: 2000 GT or GTP?
  3. #3 Re: 2000 Grand Prix GT starting issues
    St. Louis
    Quote Originally Posted by Rico View Post
    Hello,
    Thinking he has a 00 GT
  4. #4 Re: 2000 Grand Prix GT starting issues
    Apr 2009
    Fort Worth TX
    A little more research may be in order. It looks like you are just jumping the high current circuit on the fuse panel for the pump.
    Parts store I believe is correct - no fuel pump resistor circuit on the GT.
    Go back again and make sure you have spark
    Make sure you have pressure at the fuel rail - check at schrader valve
    Spark + fuel = engine runs (in most cases)
    If no start - spray some starting fluid into the throttle body and see if it sputters
  5. #5 Re: 2000 Grand Prix GT starting issues
    Jul 2012
    Midland
    I have a similar problem I need to have fixed. I fixed my AC today and was sitting in my car enjoying the fruits of my labor when all of a sudden the rpms dropped and the car died. It refused to start again. I sprayed starting fluid in it and it ran for a few seconds and died. I then listened for the pump, and nothing. Checked the fuses, all work. Even bought a new relay and replaced. Still nothing. The pins 86 and 87 on the fuse box have power, so i tried the jumping 87 to 30 on the relay, still no fuel pump priming. For ****s and giggles, replaced the crankshaft position sensor with another good one I had laying around. Nothing. Also, no security light on or anything. My only guess is that the pump just took a dive on me. Anyone second my opinion or can give another thing to check?
  6. #6 Re: 2000 Grand Prix GT starting issues
    You can try the ole hammer on the gas tank and see if you can get it to start.
    But I guess its possible the pump just died.
  7. #7 Re: 2000 Grand Prix GT starting issues
    Jun 2012
    Richburg,SC
    did the pump die ?
  1. 2000 Grand Prix GT- not starting
    By grneyes908 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:25 AM
  2. Please help, 2000 Grand Prix starting/stalling problems
    By mjs173 in forum General Tech Discussion
    Last Post: 03-19-2015, 11:22 AM
  3. 2000 Grand Prix GT not starting.
    By Grim844 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2012, 03:17 PM
  4. 1992 Grand Prix SE 3.1 starting/idling issues.
    By Borch1965 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-30-2011, 11:06 PM
  5. Problem starting my 2000 Grand Prix
    By HNorm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2011, 05:38 PM
