Thread: Popping/rubbing sound while turning right
Results 1 to 9 of 9
  1. #1 Popping/rubbing sound while turning right
    Mar 2013
    Spring, TX
    I've noticed this past week when turning right and only turning right I will hear a pop almost every time and sometimes hear a rubbing type sound.. Sounds like a plasticy rubbing noise though if you know what I mean. It doesn't sound like metal grinding. Just a pop and then a rubbing type noise. Any ideas?
  2. #2 Re: Popping/rubbing sound while turning right
    Check the plastic guards on the passenger side, that one that protects the oil filter from road debris, maybe it came loose and it rubbing the tire when turing right.
  3. #3 Re: Popping/rubbing sound while turning right
    Mar 2013
    Spring, TX
    I took a quick look in the passenger side wheel well earlier today and didn't see anything but i'll check again tomorrow when its light out. Any idea what the popping noise could be?
  4. #4 Re: Popping/rubbing sound while turning right
    CV joints can pop/click when turning.
  5. #5 Re: Popping/rubbing sound while turning right
    Mar 2013
    Spring, TX
    Thats probably it then. Should I look at getting that fixed asap? and should I just get the joint replaced/fixed or just replace the whole axle?
  6. #6 Re: Popping/rubbing sound while turning right
    St. Louis
    I'd just replace the whole axle. Get Napa axles or another good quality axle. I've read/heard bad things about the Autozone one's.
  7. #7 Re: Popping/rubbing sound while turning right
    Feb 2009
    flintnasty MI
    upper strut mounts will pop if they are worn out. You would feel it in the steering wheel, a CV would just click and or make random noise without any steering feedback.
  8. #8 Re: Popping/rubbing sound while turning right
    Mar 2013
    Spring, TX
    This sounds more like my problem. I can feel it in the steering wheel and its more of a pop than a click. It sounds like its coming from the front passenger side so what could I do to check if the strut mounts are worn out?
  9. #9 Re: Popping/rubbing sound while turning right
    Dec 2008
    Indianapolis, IN
    I get this pop sound sometimes when backing out of my driveway. It's sortof a "springy" sound, and only happens if I'm coming off the curb while turning sharp. Wonder if that's the same problem you're having.
  1. popping noise when turning right?
    By tichota126 in forum General W body
    Last Post: 03-24-2013, 04:28 PM
  2. popping/light banging from rack(?) when turning either way ?
    By reesez in forum Brakes/Suspension/Chassis
    Last Post: 08-25-2012, 10:16 PM
  3. Popping Sounds When Turning?
    By ljmonnin12 in forum Introductions/Noob Questions
    Last Post: 05-06-2011, 09:05 AM
  4. another popping thread....while turning
    By cmashark in forum General Tech Discussion
    Last Post: 04-02-2009, 04:46 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
