Thread: Help please!! No power to aftermarket HU after Bose amp removal
Results 1 to 8 of 8
  1. #1 Help please!! No power to aftermarket HU after Bose amp removal
    Apr 2012
    Wyoming, MI
    In my 2000 GTP, I have the bose system. I have an aftermarket HU and a 4-channel amp; the only thing I need for my HU is the power, ground, and remote accessory. All of the other stock speaker wires are not used. I was going to put a sub in my trunk, but the stock bose amp was in the way. As I removed it, the big connector was dangling in the way, so, I cut it, thinking it wouldn't be used because I am not using the amp. As a result, I have no power to my HU. How do I fix this without reinstalling the stock bose amp? How do I get power, ground, and remote accessory to my HU? PLEASE HELP.
  2. #2 Re: Help please!! No power to aftermarket HU after Bose amp removal
    Likely when you cut the connector instead of leaving it be, you shorted the power and ground wires together...which blew the fuse. Check fuses and tape up the power wires in the trunk so you don't have further problems.
  3. #3 Re: Help please!! No power to aftermarket HU after Bose amp removal
    Apr 2012
    Wyoming, MI
    Which fuses do you think I should start checking? Both fuse boxes, back of HU, back of aftermarket amp, etc?
  4. #4 Re: Help please!! No power to aftermarket HU after Bose amp removal
    I'd start off with the ones that are labeled "Radio".
  5. #5 Re: Help please!! No power to aftermarket HU after Bose amp removal
    Apr 2012
    Wyoming, MI
    Thank you. I'm so stupid for not checking that. All works normal now with the deleted stock Bose amp!
  6. #6 Re: Help please!! No power to aftermarket HU after Bose amp removal
    Glad it was simple... So you know..I was looking at you funny when you asked.
  7. #7 Re: Help please!! No power to aftermarket HU after Bose amp removal
    Apr 2012
    Wyoming, MI
    It was "Radio AMP" btw lol..
  8. #8 Re: Help please!! No power to aftermarket HU after Bose amp removal
    It's ok.. not many people feel the connector is in the way after removing the amp. The problem won't come up for a couple more years. Although not that long ago a guy cut the wires at the connectors at the speedo. Needless to say..he's working on 85 wire reconnect at the moment.
  1. Aftermarket head unit and Bose?
    By vncj96 in forum Audio, Security & Visual Electronics
    Last Post: 05-20-2013, 04:54 PM
  2. Aftermarket radio in a Bose gtp?
    By Jsmith309 in forum Audio, Security & Visual Electronics
    Last Post: 10-24-2011, 07:10 AM
  3. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  4. bose removal
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 01:20 PM
  5. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
