Thread: Front Grinding Noise
Results 1 to 4 of 4
  1. #1 Front Grinding Noise
    SE Level Member Axlebroskii's Avatar
    Jun 2013
    Nevada
    I've got a 2001 Pontiac Grand Prix. Occasionally when I'm driving the front end out my car makes a dull, almost-grinding noise. It's not super loud, but I can feel it vibrate a little through the floorboard. The "Low traction" light comes on in the car. It doesn't do it very often, but I want to diagnose and fix it asap. Nothing is rubbing and the tires are new. I gave it an oil change this morning and nothing looked out of place down there. My best guess is a wheel bearing, but I'd like to get a little input before doing anything.
    2001 Pontiac Grand Prix GTP
  2. #2 Re: Front Grinding Noise
    sounds like hub bearing to me.
    jack up each front wheel, lugs tight, then push and pull the top of the tire, if you feel play aka the tire moves, the hub is bad.
    bad hubs make the abs sensor not work right, same for low traction.
  3. #3 Re: Front Grinding Noise
    Jun 2013
    Nevada
    Okay, just did that. Neither tire moved.
  4. #4 Re: Front Grinding Noise
    best to find a shop that will scan the car, they charge for this most of the time.
    unless you see damaged wires to the hubs, they run along the lower control arms to the hubs sensor, they tend to get damaged. if that all looks good, get it scanned. that will pin point the problem. you could guess all day long and never get it fixed.
  1. Grinding noise when going 30 and up!
    By rbrown81 in forum General Tech Discussion
    Last Post: 11-06-2011, 08:43 PM
  2. grinding noise
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 11:28 AM
  3. 04 gt grinding noise right front
    By pmusial in forum Introductions/Noob Questions
    Last Post: 09-15-2010, 07:20 PM
  4. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
  5. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
