Thread: Mechanical or electrical gauges?
Results 1 to 9 of 9
  1. #1 Mechanical or electrical gauges?
    Dec 2012
    wichita,ks
    Which ones do I use on my 5.3? Doing a oil pressure, air fuel, and exhaust temp, or trans temp until I can get nitrous installed then ill be replacing the last one! If there's something else instead of exhaust r trans let me know!! I defiantly want my oil pressure and wideband
    It is just a FAMILY CAR
  2. #2 Re: Mechanical or electrical gauges?
    Dec 2012
    wichita,ks
    On a side note I've always had old trucks so mechinical was always used then. So I really don't know the difference just throwing that out there call me dumb or not oh we'll lol thanks guys
  3. #3 Re: Mechanical or electrical gauges?
    This difference really seems to be, do you want an oil line or a wire?
  4. #4 Re: Mechanical or electrical gauges?
    Banned
    Jan 2013
    Colorado
    electrical
  5. #5 Re: Mechanical or electrical gauges?
    Dec 2012
    wichita,ks
    Well I don't mind oil being ran through my car if you didn't hook it up wrong wont have to worry about it leaking into the cabin. But a wired gauge would be a lot Easyer to clean up in the install vs having a tube go through the car..
    and also how would the exhaust temp gauge hook up? Never had it before lol
    and I like your snore lax bill lol
  6. #6 Re: Mechanical or electrical gauges?
    Never Never Land
    Id go electric for an oil pressure gauge. For the pyro gauge(EGT) you need a probe for the exhaust. If you do a search on google for pyro gauge installs on diesels you can prob find quite a bit of info as they're pretty essential on those. Can prob even find youtube vids.
    EDIT: Lots of the diesel guys use an Isspro brand IIRC. Any pyro gauge would be fine but that's the prefernce of a lot of diesel guys.
    For the probe you have to drill and tape your manifold/header and then thread the probe in. Run it up to the gauge and run power/ground wires to the gauge. That's about the jist of it.
  7. #7 Re: Mechanical or electrical gauges?
    Dec 2012
    wichita,ks
    Alright any recommendations for a 3rd gauge?
  8. #8 Re: Mechanical or electrical gauges?
    Florida
    Aeroforce Interceptor Scangauge, or a wideband o2
  9. #9 Re: Mechanical or electrical gauges?
    Dec 2012
    wichita,ks
    I'm doing a wideband, and oil pressure and possibly that auroforce an then when I spray it ill put the nitrous pressure gauge in place of the oil pressure
  1. Mechanical Oil Pressure Gauge install
    By Frank4202 in forum General Tech Discussion
    Last Post: 04-30-2011, 10:19 PM
  2. new gas or mechanical problem?
    By PrixAngel in forum General Tech Discussion
    Last Post: 03-18-2011, 07:58 PM
  3. L67 Mechanical Specs
    By Swash in forum How To Write-Ups/Tech Tips
    Last Post: 02-10-2011, 09:00 PM
  4. I need to talk to a mechanical engineer
    By undecided in forum Off Topic Discussion
    Last Post: 01-29-2010, 11:10 AM
  5. 98 GTP, Electrical gauges and stereo and all that erase every time i shut the car off
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2009, 12:46 PM
