Thread: Help with l36 to l67 swap
Results 1 to 15 of 15
  1. #1 Help with l36 to l67 swap
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Swapping an l67 into my 98 gt, just the motor.. Just about got everything buttoned up., but I cannot get the flywheel and torwue comverter bolts to line up.i can turn the TC by hand, but the flywheel is sitting lower then the tc. Any ideas?
    p.s. Its actually a flexplate...but u get the point lol
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Help with l36 to l67 swap
    The l67 and l36 have different tc's
  3. #3 Re: Help with l36 to l67 swap
    Jul 2011
    Michigan
    So switch the flexplate or swap the tc?
  4. #4 Re: Help with l36 to l67 swap
    You could do either i think
  5. #5 Re: Help with l36 to l67 swap
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Use your GT flex since you are still using your stock trans.
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: Help with l36 to l67 swap
    You have two choices. Pull engine and swap plates or open up the holes a bit and bolt them up. I'm not outright suggesting the second as it's not the "right" way. I have done it 2 times for friends when no other option was available and both cars are still good 2-4 years later.
    SC is a 258mm pattern
    NA is a 245mm pattern
  7. #7 Re: Help with l36 to l67 swap
    Jul 2011
    Michigan
    have you heard of anything going wrong when doing it this way
  8. #8 Re: Help with l36 to l67 swap
    Not in the 4 years it's been done, no.
    One car has a plog, 1.9's (no u bend because it'a a Bonneville), 3.4" pulley etc. And believe me...the girl blew her last motor racing, she's not gentle on it.
  9. #9 Re: Help with l36 to l67 swap
    Jul 2011
    Michigan
    Also bill, my oil pan is dented. Its not terrible, but will it effect the oil pickup?
  10. #10 Re: Help with l36 to l67 swap
    I can't see how bad or where it is from here. Got a picture?
  11. #11 Re: Help with l36 to l67 swap
    Jul 2011
    Michigan
    I can get one when I get home from work
  12. #12 Re: Help with l36 to l67 swap
    Sounds good.. you like the added humor?
    Typically you can dent these pans up decently w/o hurting the pick up. Tough to say w/o knowing what it looks like.
    On the flex, I see it this way and some may disagree. You can egg the holes and give it a go or pull the motor, put the other flex on and in the end..who knows, maybe either of them crack in time. I was very lucky and never cracked one. Mine had been drilled for 245MM by Intense and never gave me any trouble.
  13. #13 Re: Help with l36 to l67 swap
    Jul 2011
    Michigan
    lol yes i did bill. I was just at work and should not have been on here lol. But here is the pic of the oil pan. And a pic of the motor ( just because lol) and a pic of the homemade supercharger pulley presser on'er lol, worked like a champ!! lol. The oil pan is dented slightly on the other side, But thats the worst in the pic
  14. #14 Re: Help with l36 to l67 swap
    You'll be fine with that dent. Hell..when you jack on the pan, usually you'd put a worse dent in it.
  15. #15 Re: Help with l36 to l67 swap
    Jul 2011
    Michigan
    Do you know how far the pickup tube is from the.pan? Thanks btw!
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  3. DBW TB Swap
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2012, 04:12 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
