Thread: Maintenance gone wrong - wires/plugs - NOT RUNNING
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    last time i did plugs/wires. car would start, then die right away,
    silly me i knocked the vac line off going to the brake booster
    edit, also ive recently been playing with vacuum on my car, looking at gauges/scantool, and ive unpluged the map on the car and it still idled fairly well...
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  2. #22 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    SE Level Member HEVEYMETIL's Avatar
    Western New York
    The nipple has completely snapped off - it appears that it was a stress fracture and this is the last "jolt" it needed. The nipple is still in the vac line. Does everyone agree that this would cause an extremely rough idle?
  3. #23 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Quote Originally Posted by Seachicken View Post
    I'm hoping this is it - but if not, I can solve this problem at the same time...at least it may run BETTER and I can really figure out what the deal is.
  4. #24 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    broken vac line is a instant idle problem.
  5. #25 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Pennsylvania
    Quote Originally Posted by HEVEYMETIL View Post
    I have checked the firing order over and over. All connections secure.
    I hate to say it, but check a couple more times.
    When it starts, it start strong and about a second after, sounds like death. Roughest idle - surging - running rich - gets close to dying then sputters back to life...
    this sounds like it could be a ripped injector wire or an unplugged/broken/dirty MAF sensor to me. A little vacuum leak shouldn't cause that bad of an idle.
    Is copper a problem? Everyone here says they're the best to run.
    Who's this "everyone" you talked to?
    Try removing that grease.
    good suggestion.
    Perhaps I will drop the gap a bit to see if that works
    Your gap is fine, don't worry about it.
    A good thing to do at this point is to pull every plug and see which one is wet with fuel. That will at least give you a good spot to start.
  6. #26 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Thanks for the suggestions, Gentlemen, each was helpful. I'm going to tackle all this tomorrow after work - yeah, i get to sleep on it and then think about it for none hours then do it - always fun. Keep the ideas coming and I'll be sure to respond when all is figured out.
  7. #27 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    that is 100% your problem you are going to have to replace your map sensor. Get one new if you cant one from the junkyard will work fine just take the peice that broke off inside out and hookup the new maf and your problem will be fixed
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  8. #28 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Quote Originally Posted by Ginseng View Post
    Wish my yards were open later here. I called LKQ and they had nothing. AdvancedA couldn't get it to me until the 12th. NAPA it is - for a hundred. And it'll be in today. Sigh...
  9. #29 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Think the last time I got one was from RockAuto for my GT...
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  10. #30 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    gardner,mass
    adanced fail, i have one in stock at my store for 67 bucks. im looking at it right now
  11. #31 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Nov 2009
    Tennessee
    RockAuto, ACDelco part $27.79.
    Problem is, looks like you completely broke the tabs that hold it in place also... Did you?
    Sorry just looked, you have an '07... I looked up for an '06.... Don't know what the difference is, other then $10...
  12. #32 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Quote Originally Posted by dbextreme View Post
    Could the MAP sensor been jared?? With it above the #2 and arms down behind it pulling and jerking it could have gotten hit and the vacuum unplugged?? Just a thought..
    Thanks to all of you, especially dbextreme for narrowing down the problem exactly.
    Got the new MAP installed and after figuring out that the other MAP is used for a baro-sensor, the car started, choked for a second, then fired right up into an excellent idle. Everything seems back to normal, but I'm of course worried that I damaged something in the process. Idle seems great, car heats up, no funny smells - I think we're good to go.
    Thanks again, guys.
  13. #33 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Pennsylvania
    You can knock the hell out of it at idle for a few minutes with no ill effects. Pretty tough engine. Sleep sound.
  14. #34 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Quote Originally Posted by SlowNA06 View Post
    Thanks, Slow. Drove the car to work this morning - all seems great and I feel better knowing what I know now. Knowledge is always power.
  15. #35 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Relax and enjoy it..
    These motors take a serious pounding in many ways. I drove abotu 10 miles with every light and bell screaming at me on a Series I motor. Come to find out..the low coolant light was correct..lol Fixed, never another issue
    Had an air bubble from hell on my S2 another time.. stalled at idle from heat. Got that burped..no issues ever again
    Often I cross a couple plug wires.. no worries.. fix them and it's all good
    You likely didn't hurt a thing.
  16. #36 Re: Maintenance gone wrong - wires/plugs - NOT RUNNING
    Western New York
    Thanks, Bill. After this experience, I'm confident to do more stuff. I'm almost 30 and it's taken me this long to figure out "if I break it, I can fix it".
    It also amazes me that with these engines (and every other motor) being soley reliant on technology to run, one small hiccup can cause a world of " is going on"?
  1. Plugs and wires
    By bjordan0223 in forum 5.3L V8 (LS4)
    Last Post: 08-17-2012, 07:53 PM
  2. Plugs?? Wires??
    By Speedy1973 in forum Engine
    Last Post: 06-22-2012, 09:14 PM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. Best plugs&wires for a 99 GTP
    By MurphysLaw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2010, 08:58 AM
  5. Plugs and Wires
    By Squishy in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-09-2009, 09:51 PM
