Thread: My car keeps dying on me.. Help..
Results 1 to 10 of 10
  1. #1 My car keeps dying on me.. Help..
    SE Level Member Akcalvinkid's Avatar
    Mar 2013
    Ocala FL
    Okay so I drove my car this morning, and it drove perfectly fine, it didn't give me a single problem. Then when i came home, i turned the car off and went in side. Then about ten minutes later when I came out side i started my car back up and It started doing this to me.. By the way it hasn't ever given me any problems before.. Here is a video of what it is doing.... After a few seconds the engine stops then nothing..
    My car.. - YouTube
    1998 Pontiac Grand Prix Pace Car Daytona 500 edition
  2. #2 Re: My car keeps dying on me.. Help..
    Try unplugging the maf. If that doesn't work do the fuel pump resistor bypass thing.
  3. #3 Re: My car keeps dying on me.. Help..
    Just for ****s and giggles, try unplugging the MAF sensor and see if runs for longer.
    It might also be the fuel pump relay/resistor issue aswell.
    Sounds like it either running out of fuel or the MAF sensor is dying and causing it to run really rough and die.
  4. #4 Re: My car keeps dying on me.. Help..
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Fuel pump Resistor is bad. Bypass it problem solved.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: My car keeps dying on me.. Help..
    Oct 2011
    MI
    Your s/c coupler is shot as well.
  6. #6 Re: My car keeps dying on me.. Help..
    Mar 2013
    Ocala FL
    Yeah I need a new s/c coupler to fix the sound I know. But I have the car working and running, I pulled fuse 15 out, and I bent pin 85 out of the way, and I plugged it back in. So now the car is running!
  7. #7 Re: My car keeps dying on me.. Help..
    Oct 2011
    MI
    Easy as lemon sqeezey
  8. #8 Re: My car keeps dying on me.. Help..
    Yay i was right
  9. #9 Re: My car keeps dying on me.. Help..
    Mar 2013
    Ocala FL
    now I just have to get rid the loud noise, by fixing the coupler
  10. #10 Re: My car keeps dying on me.. Help..
    Easy enough. Good luck on your journey to getting to know your gtp
  1. She's Dying.
    By ThirtySix in forum General Tech Discussion
    Last Post: 04-02-2013, 09:52 PM
  2. Engine dying
    By PaulGoldstraw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2012, 10:20 AM
  3. 01 gt dying a lot
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 09:18 PM
  4. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
  5. Car keeps dying
    By jakeeck in forum General Tech Discussion
    Last Post: 02-19-2009, 12:26 AM
