Thread: cam help
Results 1 to 18 of 18
  1. #1 cam help
    Nov 2012
    pa
    Lift: .531"/.531"
    Duration: 264/274
    Lobe Separation Angle: 115°
    RPM Range: 1000-5500
    what type of cam is this ? and what mods do i need to run this mods i have to support it r ls6 valve springs, 3.2 pulley headers and 42.5 lucas injectors and goin make a 3inch custom exhaust.
  2. #2 Re: cam help
    Nov 2012
    pa
    cam was giving to me as a gift
  3. #3 Re: cam help
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Those duration numbers don't sound right at all. What engine is this for? The lift numbers, are those with or without the rockers?
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  4. #4 Re: cam help
    Nov 2012
    pa
    there with out. its from jegs for a l36 my uncle was building a 3800 he bought this cam he said its a off set kind i dont know i really dont know much about cams
  5. #5 Re: cam help
    Jul 2012
    do you have the name of the company? I.E. Comp Cams or Lunati?
  6. #6 Re: cam help
    Nov 2012
    pa
  7. #7 Re: cam help
    Jul 2012
    Without knowing anymore info. I would say that the cam you have is NOT for a L36 engine. .531 lobe lift just sounds way,way,waaaaay off. I'm running a TOTAL lift (that includes a 1.7 rocker ratio) of .538, which is very close to maximum on stock heads. The durations for intake/exhaust are far too big for our engines as well. Unless it's the advertised durations and not the durations at.050 lift.
  8. #8 Re: cam help
    Jul 2012
    O.K....that helps a lot. Do you have the spec. card that came with the cam?
  9. #9 Re: cam help
    Nov 2012
    pa
    thats the spec card that came with the cam i lost it and had jegz send me the secs in my email
  10. #10 Re: cam help
    Nov 2012
    pa
  11. #11 Re: cam help
    Jul 2012
    I'm gonna assume that the advertised lift for intake/exhaust is including stock rocker ratio of 1.6 - if it IS just lobe lift and not total lift, then you are looking at a total lift of .819 to .849...dunno of anyone ever attempting to run that much lift on a 3800 - The next problem I see is the two different lifts advertised. one screen says .531 lift, but under specification tab it's advertised as .512- I suggest contacting Comp and/or Jegs to straighten this out.
  12. #12 Re: cam help
    Jul 2012
    The reason I say this is one will require minor valvetrain mods., while the other will require a bit more.
  13. #13 Re: cam help
    Nov 2012
    pa
    ok thank i will call trmw
  14. #14 Re: cam help
    Jul 2012
    where in PA are ya?
  15. #15 Re: cam help
    Nov 2012
    pa
    Pittsburgh,
    and i got a hold of them thats the spec onces its installed with the 1.6 rockers its 531/531 and before install its a .512/.512 and the rpm is 1000-6500 thats the last time i deal with jegz
  16. #16 Re: cam help
    Nov 2012
    pa
    mods im running is a top swap gen 3 3.2 pulley 42.5 lucas headers full exhaust ls6 springs and tune of course lol im doin a pre gen swap gtp in my 95 which needs to be done soon moving to fl
  17. #17 Re: cam help
    Apr 2011
    Vassar, Mi
    I have that cam, it rocks. My car went 13.33 @ 104 with it, with a 3.4 pulley, headers and a tune, im running it on l76 springs and retainers. Went 12.84, same setup, with the addition of E85 and a 3.1 pulley. Drives like stock, mileage is a little low for me though, around 17 city/25 hwy
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  18. #18 Re: cam help
    Jul 2012
    Quote Originally Posted by Anthony Smith View Post
    There ya go! He can tell ya everything you should need
cam
