Thread: pinging only under load WHY ???
Results 1 to 5 of 5
  1. #1 Re: pinging only under load WHY ???
    Banned
    Wichita Falls, Texas
    Check the plugs, wires, coils, then the ignition module. Probably the ignition module, but thats also the most expensive part. So you should check the cheap junk first just in case.
  2. #2 Re: pinging only under load WHY ???
    SE Level Member GAGT+GP-OWNER's Avatar
    May 2008
    DARTMOUTH, NOVA-SCOTIA,CANADA
    well only one day 1/4 down from full tank of the higher octane 91 and the winter gasline antifreeze. i notice that i do still have a ping AT TIMES and RATHER lower in volume with none LOADS in the car. and only occurs with tramping on gas for a second. i know it maybe too early yet to see what effect on this pinging ( if any ) the higher octane 91 gas + gasline antifreeze + plus added today stp 2 in 1 octane boost that cleans also.
  1. Replies: 0
    Last Post: 08-24-2008, 12:43 PM
  2. Pinging???
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2008, 11:41 AM
