Thread: are these tire pressure sensors one in the same / exact same
Results 1 to 10 of 10
GAGT+GP-OWNER are these tire pressure... 09-26-2008, 08:18 PM
DnaProdigy Re: are these tire pressure... 09-27-2008, 02:37 AM
GAGT+GP-OWNER Re: are these tire pressure... 09-28-2008, 12:19 AM
tod1d Re: are these tire pressure... 09-28-2008, 12:45 AM
GAGT+GP-OWNER Re: are these tire pressure... 09-28-2008, 01:03 PM
Reptile Re: are these tire pressure... 09-28-2008, 02:01 PM
GAGT+GP-OWNER Re: are these tire pressure... 09-29-2008, 05:37 AM
tod1d Re: are these tire pressure... 09-29-2008, 07:02 AM
GAGT+GP-OWNER Re: are these tire pressure... 11-04-2008, 01:08 AM
02BlueGT Re: are these tire pressure... 11-04-2008, 01:18 AM
  1. #1 are these tire pressure sensors one in the same / exact same
    SE Level Member GAGT+GP-OWNER's Avatar
    May 2008
    DARTMOUTH, NOVA-SCOTIA,CANADA
    for my 2007 gp 3.8L i am looking for sensors to install in some winter steel rims.
    gm gives me a part number 15921013, FROM THERE COMPUTOR .
    THE SENSORS THEY HAVE ACTUALLY ARE STAMPED FCC :KR5S120123009 , OR PART NUMBER >S120123009A.....
    NOW serveral ebay sellers of used parts have the number listed FCC:KR5S120123007 OR PART NUMBER > S120123007B.
    AND THEY TOO LIST THEM FOR 2007 GP SEDAN . ARE THESE 2 SENSOR THE ONES GM SELLS AND THE ONES EBAY SELLERS ADVERTISE THE EXACT SAME SENSOR. IF SO I CAN GET THE FOR A GREAT PRICE > KR5S120123007
  2. #2 Re: are these tire pressure sensors one in the same / exact same
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    I recommend emailing/contacting the seller on ebay and asking what applications the parts are good for. Most sellers actually want to get rid of their item so they will be as helpful to you, the buyer, as possible.
    2006 Grand Prix GXP
  3. #3 Re: are these tire pressure sensors one in the same / exact same
    May 2008
    I JUST WOUNDER IF THE DIFFERENCE IS SENSORS ENDING WITH 7 ARE for usa cars only ( none metric reads on the dash monitor ) ?????
  4. #4 Re: are these tire pressure sensors one in the same / exact same
    May 2008
    Winnipeg, MB
    that shouldn't matter as you can convert all readings from either metric or imperial
    2007 Pontiac Grand Prix
  5. #5 Re: are these tire pressure sensors one in the same / exact same
    May 2008
    Yu mean me convert . No thank you. So do you think there are usa only car sensors for my car that would not work 100% properly .
  6. #6 Re: are these tire pressure sensors one in the same / exact same
    Bastard Reptile's Avatar
    Kansas City, MO
    I don't know about these, but all the ones that GM sells are pretty much the same, they eventually superceeded all of them to the same part number.
  7. #7 Re: are these tire pressure sensors one in the same / exact same
    May 2008
    not following you reptile
  8. #8 Re: are these tire pressure sensors one in the same / exact same
    May 2008
    Winnipeg, MB
    converting readings is a setting in the DIC
  9. #9 Re: are these tire pressure sensors one in the same / exact same
    May 2008
    so do those of you with the USA 2004 to 2008 gp have your DIC able to show in both metric and non-metric like the cdn gp do ? if so then i would think your sensors on the wheels would also be the same even if the numbers actually stamped on the sensors differs abit as i easlier mentioned.
  10. #10 Re: are these tire pressure sensors one in the same / exact same
    Hoffman/Schaumburg, IL
    Just so you know CAPS LOCK MEANS YOUR YELLING
    But, the sensors would be the same CDN vs USA, It is too costly to use a different sensor for the same thing, the conversion from standard to metric and back is all handeled by the software in the computers, if you look at your dash, there is a light on the speedo for MPH, in the US cars you can switch back and forth from the MPH to KMPH and the light changes and the needle re adjusts, it is all in the computer, contact the seller, or just buy the ones from GM if you are worried about getting the right ones
  1. ABS and Tire Pressure Lights on
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2010, 10:05 PM
  2. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  3. Tire Air Pressure
    By 03GPScottyd in forum Tires & Wheels
    Last Post: 08-04-2008, 11:07 AM
  4. Tire Pressure System not working.
    By xray328 in forum General Tech Discussion
    Last Post: 05-13-2008, 08:43 AM
  5. ABS and Check Tire Pressure with hard steering
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-09-2008, 04:32 PM
