Thread: Headlights WONT WORK
Results 1 to 3 of 3
  1. #1 Headlights WONT WORK
    Mar 2013
    Burton,MI
    A couple days ago my headlight assembly on my driver side came out while i was on the road. Since then my headlight was trashed so then a bought a brand new pair on ebay and when i was all good and done my low beams wont work but my high beams on the driver side work. Checked the fuse and they all work any ideas please help!!!
  2. #2 Re: Headlights WONT WORK
    I live here. DirtDog's Avatar
    Jun 2012
    Check all the wiring and the ground from the headlights that's behind them
  3. #3 Re: Headlights WONT WORK
    Florida
    Check all your connectors pertaining to the headlights. Make sure that all the pins are seated correctly.
    If you have a multimeter, make sure you have a good ground (continuity) and make sure you're getting voltage at each connector.
  1. Replies: 3
    Last Post: 03-01-2013, 08:37 PM
  2. My windows wont work.... HELP is appreciated
    By nickskip08 in forum Introductions/Noob Questions
    Last Post: 01-16-2013, 11:30 PM
  3. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  4. ddm hid fogs wont work
    By gpgt04 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 12:37 PM
  5. Car wont start on initial try, will work 2nd try always
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 10:44 AM
