Thread: Car wont start on initial try, will work 2nd try always
Results 1 to 10 of 10
  1. #1 Car wont start on initial try, will work 2nd try always
    Connecticut
    In advance thanks for the help...
    My issue is this, after my car sits for about a couple hours or more it has difficulty starting. The starter itself is fine. Ill turn the key to try to start the engine but the motor just keeps turning over and over. I let off the start and wait a few seconds and try again and it starts the 2nd try. I have even tried letting the car sit in accessory thinking maybe the fuel pump needs to build some initial pressure but that doesnt help either. Once the car is started it runs like a champ with no fuel issues.
    I want to get a remote start put into my car but this issue needs to be fixed first.
    Could it be a fuel filter problem or a fuel pump issue? Whats all your inputs?
  2. #2 Re: Car wont start on initial try, will work 2nd try always
    SE Level Member almighty's Avatar
    northern illinois
    cycle the key a few times, turn car on turn car off, then start, if it starts the first time it could be the fuel pump getting a bit weak, i have seen cars and truck that last for years like this, but i have also seen pumps die immediately. if this test is successful it may also be the filter but thats cheap and easy to fix
  3. #3 Re: Car wont start on initial try, will work 2nd try always
    Connecticut
    Yea, after I get it to start and run I can turn the car off and on as much as i want. I was getting it was maybe the fuel pump but I just wanted to make sure before I go into that whole ordeal
  4. #4 Re: Car wont start on initial try, will work 2nd try always
    Largo, Florida, United States
    could be a o2 sensor as well.
  5. #5 Re: Car wont start on initial try, will work 2nd try always
    Charles City, IA
    No, the car does not look at that for starting.
    SMGPFC Two Nipple General
  6. #6 Re: Car wont start on initial try, will work 2nd try always
    Apr 2009
    stockton ca
    Nope
  7. #7 Re: Car wont start on initial try, will work 2nd try always
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I've heard similar things on guys with leaking injectors. They leak all night for example and in the morning you'll have problems turning the engine on due to excesive fuel that has been leaking.
  8. #8 Re: Car wont start on initial try, will work 2nd try always
    Charles City, IA
    Also I bet it is the fuel pump. Also check the fuel pressure regulator.
  9. #9 Re: Car wont start on initial try, will work 2nd try always
    Connecticut
    Thanks for all the input people. Gonna work on it this weekend
  10. #10 Re: Car wont start on initial try, will work 2nd try always
    Banned - Busted For Scamming
    Feb 2009
    Probably a leaking injector.
  1. dash lights wont work!!! please help
    By jshuman in forum General Tech Discussion
    Last Post: 02-23-2010, 09:06 PM
  2. Help AsAp Cluster wont work!!!!
    By princequeeley in forum Introductions/Noob Questions
    Last Post: 06-09-2009, 03:24 PM
  3. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  4. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
