Thread: Ticking sound coming from under the hood, Only under acceleration tho...???
Results 1 to 20 of 23
  1. #1 Ticking sound coming from under the hood, Only under acceleration tho...???
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Car is a 2006 GPGT and noticed this in February, it hasn't got better or worse but now is really bugging me.. Its a slight ticktickticktick almost sounds like a lifter tick, but not as loud.. Ive seen some people suggest valve lash, spun bearing, seal, Crack in HG etc, but we are going to start small first.. Could it be something like an exhaust leak somewhere? Is there some kind of donut gasket off the mani??
    I would take a vid but you would never hear it over the wind noise... But when I get a chance I will go put it in drive and hold the brake to get a load on the motor and see if I can get a sound out of it
    But does anyone have any ideas??
  2. #2 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    take the belt off fire it up for a minute, see if the sound is gone. dont drive it with belt, it will over heat, this is to see if its the pulleys.
    once the belt is off spin all the pulleys, make sure they are smooth rolling. test the water pump to by pushing one side and pulling the other of the pulley, if it moves, its going bad.
  3. #3 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Nov 2012
    MN
    Thanks man, Actually just did that last week, bad squeeking/ticking, .. Waterpump was shot... So it actually has a new pump and belts, and the rest of the pulleys are good
  4. #4 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    could be a exhaust leak, when you first start the car up in the morning, or after its good and cold. start it up, and feel around with your hand if theres a leak, you'll feel the air hit your hand. you have limited time doing this as the manifolds heat up pretty fast.
  5. #5 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Nov 2012
    MN
    Coudnt I just dump a little seafoam in the gas tank as well?? Im guessing it would smoke pretty good if there was a leak?
  6. #6 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    you could, but you need to follow the directions on the can and dump one 1/3 into a vac line, then shut the car off for 15 minutes, then fire it up. then it should smoke. and of course if theres a leak, the smoke should be seen under the hood or along the exhaust pipes out the back.
  7. #7 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I tried the seafoam trick to find a leak in my exhaust. Didn't see any smoke from the exhaust. Tomorrow (while it's already up on blocks) I'll start it up and feel with my hand around the exhaust, starting with the manifolds.
  8. #8 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    May 2008
    Winnipeg, MB
    My car ticks loud when first fired up when cold and its from the PLOG, it goes away once its warmed up so is it realy a problem?
    2007 Pontiac Grand Prix
  9. #9 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    GTP Level Member
    Sep 2011
    Motown
    Do you have a CAI on there?
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  10. #10 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Quote Originally Posted by Classy Pontiac View Post
    I noticed that on my 04 Comp-G, after I installed my CAI the motor began having a slight tick/clattering upon acceleration. Before it was just so ****ing quiet. Can't make the sound in park either.
    (Only noticed it on that hotter day where I rolled with windows down for once since a while.)
    Figure it could be similar for the OP, these motors are just such big noise machines.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  11. #11 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Nov 2012
    MN
    Yea Im hoping its just a small leak somewhere.. Exactly how do you use the seafoam ? Dump it in the oil,? gas tank? and also how do you get it in the vac line?
  12. #12 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Sep 2012
    Clarkston, MI
    Take the big vac line off the brake booster. Engine will studder and die if you don't hold your finger on it. I used a funnel and just kept blocking the hole with my finger as I poured the seafoam into the funnel. Then let the seafoam slowly get sucked in. When you're close to done, pour a lot of seafoam all at once so the engine dies and let it sit for about 10 minutes. Then start 'er up (it'll be hard to start it at first). I actually used the whole bottle doing this. Got carried away but it didn't hurt anything. Quite a smokeshow after I let it sit 10 minutes. Anyway, after you let it sit 10 minutes and get it started, look for leaks in the exhaust from the smoke. This didn't work for me though. Sorry for long paragraph, my enter key isn't working for some reason.
  13. #13 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    GTP Level Member
    Sep 2011
    Motown
    Once I put a CAI on my car there was a clicking sound upon acceleration but never happened in park or neutral. I then put the factory air box back in and nothing, no ticking sound. So I just put the CAI back on and said the hell with it.
  14. #14 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Nov 2012
    MN
    Ill give the seafoam a try.. But now that it was mentioned.... I didnt notice any ticking before I put the cone filter on the end of the MAF
  15. #15 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Jul 2012
    Chicago
    My car ticks under partial throttle. Started after intake install as well.
    -Carl
  16. #16 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Nov 2012
    MN
    Quote Originally Posted by nos4blood70 View Post
    if this is the actual issue, any idea why?
  17. #17 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    the stock air box is a muffler too. take it off and run a cone and you hear all sorts of new sounds.
  18. #18 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Nov 2012
    MN
    I have a 2000 ssei with a intense level 1 kit w the FW intake, and I dont hear it at all
  19. #19 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    maybe the longer the tube the less you hear, at start up when cold, mine sounds like its eating rocks, im told its the iat sensor.
  20. #20 Re: Ticking sound coming from under the hood, Only under acceleration tho...???
    Dec 2010
    DMV
    ^mines too. I'm thinking I should get a longer tube. I hate the noise.
  1. Loud ticking noise on acceleration
    By cameron92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2012, 07:48 PM
  2. ticking sound
    By devinbajus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2012, 03:27 PM
  3. Any ideas on a ticking sound?
    By Drew86maro in forum Engine
    Last Post: 09-30-2010, 11:25 PM
  4. Engine ticking sound
    By zildjian102 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:24 AM
  5. weird ticking noise coming from turbo
    By lilredss0287 in forum Turbo
    Last Post: 09-05-2008, 08:56 PM
