Thread: Car using alot of gas- Frusterated
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Car using alot of gas- Frusterated
    GT Level Member Shiftingshaddow's Avatar
    KC
    i don't know how you drive or how much is highway but missing overdrive gear will take about 4-6 mpg off highway. if you were getting 22 highway that is horrible to start with. it should be 28 mpg highway and 18-20ish city.
    to make sure its working, drive the car at 70 mph or so and look at the rpm's. they should be at 2000. if they are at 3000 you have lost overdrive.
    the driver center, the thing that tells you your fuel mileage, is an average reading. so if you are driving on the highway your average mpg reading will go down if you don't have overdrive.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  2. #22 Re: Car using alot of gas- Frusterated
    GT Level Member Mikey Bonefas's Avatar
    May 2012
    Waterloo, IA
    im almost betting it is the MAF, im having the same problem.
    but its whatever, idles fine and doesnt cut off..yet.
  3. #23 Re: Car using alot of gas- Frusterated
    Mar 2012
    Michigan
    Car is running smoothly, getting reading from my info center in car,which now I am getting 17.6 mpg on highway instead of 16 mpg and my service soon engine light is not on. Also keep hearing this hissing or air leak sound around my air filter hose that is connected to my engine,buts it's not coming from that. The only other thing I could think of is my tranny
  4. #24 Re: Car using alot of gas- Frusterated
    Mar 2012
    Michigan
    Oh and rpms are at 2000 at 70 mph on highway
  5. #25 Re: Car using alot of gas- Frusterated
    You do reset the info center while you drive right?
    The trans sounds normal to me, rpms should be at 2,000 at 70mph.
  1. Still frusterated On 2001 3.8L V6 grand prix gt
    By sammie in forum General Tech Discussion
    Last Post: 06-06-2012, 11:48 AM
  2. New guy from ohio ! alot to say !
    By Dobbs122 in forum Introductions/Noob Questions
    Last Post: 09-18-2010, 10:17 PM
  3. Need alot of help please
    By erod78 in forum General Tech Discussion
    Last Post: 06-17-2009, 12:26 AM
  4. Going through alot of Coolant
    By mikroehl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2009, 04:16 PM
  5. joined a while ago but been on alot lately
    By toffog87 gtp in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:45 PM
