Thread: Help on shift kit
Results 1 to 9 of 9
  1. #1 Help on shift kit
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Hey guys, I have a Transgo Shift kit and I was going to switch the trans fluid and filter today, so might as well tackle the shift kit. So I know you have to unbolt the accumulator and open that up to swap the springs, but the instructions aren't very clear that came with the kit. Also to my understanding, the kit comes with extra parts intended for a full rebuild. Which of these springs/spacers are the extras?
  2. #2 Re: Help on shift kit
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Easy.....since you're not opening up the side of the trans the 3 things at the bottom of you pic and the yellow spring you won't be using.
    I know I'm going a little off of what the directions says but use bare metal, white and red springs so both accumulators look the same. One long brass spacer on each accumulator at the bottom and the short brass spacer on the top of the 2-3 accumulator.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: Help on shift kit
    Make sure you use 6 sided sockets on the bolts.
  4. #4 Re: Help on shift kit
    Nov 2011
    Indiana
    alright so in each section of the accumulator, put 1 long brass spacer in, followed by one red and one white? Then in the 2-3 accumulator, put the short brass spacer (you said spring) on top of the long brass spacer The gray/black bigger springs aren't used?
  5. #5 Re: Help on shift kit
    Nov 2011
    Indiana
    can do, ive got the tools for it, just have snow coming today so not sure if i'll pull the car in the garage and do it or wait til next week. But i wanted to get my instructions correct first.
  6. #6 Re: Help on shift kit
    Apr 2011
    Columbus, OH
    Correct, you're stock bare metal bigger springs aren't used...
    Not sure how much easier I can make it. Use plain, white, red, long spacer in the bottom of both. Re-use original top bare metal springs with just the addition of the smaller spacer on the 2-3 accumulator.
  7. #7 Re: Help on shift kit
    Nov 2011
    Indiana
    ya i was just looking at that and make picturing things easier. so the springs on top of that circular thing are reused? but just add the medium spacer in the 3rd piston bore?
  8. #8 Re: Help on shift kit
    Apr 2011
    Columbus, OH
    Yep, top plain springs are re-used.
  9. #9 Re: Help on shift kit
    Nov 2011
    Indiana
    allllrighty thank you very much.
  1. Which shift kit to get?
    By rhenuset in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2013, 01:29 PM
  2. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  3. shift kit, on 20's
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-27-2010, 08:51 PM
  4. won't shift out of first very well
    By melwil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2009, 01:07 AM
