Thread: Which shift kit to get?
Results 1 to 20 of 23
  1. #1 Which shift kit to get?
    SE Level Member rhenuset's Avatar
    winnipeg
    I am looking for a shift kit but want a little input from others before I buy and waste some money. I have seen the triple edge, transgo, zzp and some other kits but they all say they have their own bells and whistles. I'm not concerened about price, just want to know what would be the best for me (Im sure they are all more or less the same but you get what I mean). I use this GP as a daily driver so I dont need crazy harsh shift or anything, just enough to feel it shift harder and be friendly to my tranny. thanks
  2. #2 Re: Which shift kit to get?
    Trans Go or Intense.
    Without taking the trans apart you can't do a full on shift kit, but with the pan drop you do change the springs and add spacers which does help.
  3. #3 Re: Which shift kit to get?
    TransGo is better for the stock~ish non-performance setup...it's better than stock but jsut firms up the shifts a little...
    Intense is the slapbang awesome kit that pwns. Get that one if you're looking for a hard, fast shift.
  4. #4 Re: Which shift kit to get?
    winnipeg
    Alright thanks. Ill look more into those two and decede from that.
    I see on the transgo it says no 4th. What do they mean by that?
  5. #5 Re: Which shift kit to get?
    Howell, NJ
    Do you think the intense would be too much for a daily?
  6. #6 Re: Which shift kit to get?
    winnipeg
    Nevermind with the 4th thing. i wasnt thinking clearly.
    I live here. DirtDog's Avatar
    Jun 2012
    I have the combo transgo kit from TEP and I am very satisfied with it and how it makes trans perform.
    Sent from my DROID RAZR using Tapatalk 2
  8. #8 Re: Which shift kit to get?
    May 2008
    Schuyler, NE
    Keep your trans stock, and get a tune instead.
  9. #9 Re: Which shift kit to get?
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    ^ thats what i did and got good performance
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  10. #10 Re: Which shift kit to get?
    Quote Originally Posted by Erik Adam Rodriguez View Post
    You got a canned PCM according to your sig...so...meh.
  11. #11 Re: Which shift kit to get?
    Sep 2012
    bridgeport,NY
    o so you gunna tune it right zzp messed up mine so i kept the stock pcm to tune
  12. #12 Re: Which shift kit to get?
    The Boss Iceman6669's Avatar
    Jun 2011
    If not him then get someone to do a custom in car tune for you.....
    2011 F-150 Yote powered
  13. #13 Re: Which shift kit to get?
    Sep 2012
    bridgeport,NY
    no one in ny and reptile dont answer pms
  14. #14 Re: Which shift kit to get?
    Jun 2011
    There are guys in your area.. Lots of guys in the upper east coast. Might have to make a day outta it but it is something I would do.
  15. #15 Re: Which shift kit to get?
    There are tons of wbody people in New York...
    Here: Northeast
  16. #16 Re: Which shift kit to get?
    Sep 2012
    bridgeport,NY
    i checked it out thanks for link
  17. #17 Re: Which shift kit to get?
    winnipeg
    I had a tune before and then my car started killing me economy very badly so I got rid of it. This is why I want the shift kit
  18. #18 Re: Which shift kit to get?
    Quote Originally Posted by rhenuset View Post
    Because canned tunes run piggy rich.
    Hence why I say get an in car tune.
  19. #19 Re: Which shift kit to get?
    May 2008
    Schuyler, NE
    Quote Originally Posted by blueguy91 View Post
    They usually will at WOT. Not at cruise. They still command 14.7afr in closed loop. If his MPG decreased, it had nothing to do with his PCM.
  20. #20 Re: Which shift kit to get?
    Hate me all you want guys, but both the Intense kits and Trans go kits are the same IMO. Both are safe for the street. One kit just has parts sourced from a different distributor, a scotch brite pad, filter and gasket.
  1. Replies: 1
    Last Post: 12-08-2012, 07:39 PM
  2. Wot pop/cut out at shift
    By DaytonaGTP500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2012, 12:59 PM
  3. Shift
    By GTP78 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2012, 08:08 AM
  4. what shift kit should i use.
    By 00pontiac1971 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2008, 09:06 PM
