Thread: aeroforce elp please!!
Results 1 to 20 of 21
  1. #1 aeroforce elp please!!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i just bought an aerofoce scan gauge and it has that feature where the red lights come on depending how you set it well i cant seem to disable it or change it, i turn annunciator mode off then it goes away until i turn the car off and back on then annunciator mode is back on again!! i tried setting it to something that would never have those stupid red lights come on but i cant change that either!!! there always on its driving me insane im about 2 seconds away from trashing this thing!! please help
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: aeroforce elp please!!
    If it wasnt saturday, I would contact aeroforce themselves.
    I can't say I've had that issue, once I turn that feature off you just unpluged it, it would reset to the default.
  3. #3 Re: aeroforce elp please!!
    Oct 2011
    Michigan
    ive unplugged it, did nothing just resets to having that feature on. ive turned it off (like i said) once i turn the car off then back on the feature is on again
  4. #4 Re: aeroforce elp please!!
    Oct 2011
    Michigan
    Figured it out.....at least how to make the lights stay off
  5. #5 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Hey asite, I have a question if you don't mind helping me out. I just, bought an aeroforce the other day and I can get the vacuum/boost. What does it show up as? Only place I can find it is in analogues. N I set slope to 14 n intercept to -14 and when I wot it doesn't fluctuate.
  6. #6 Re: aeroforce elp please!!
    Boost is MAP in/hgs.
    You have to read the MAP sensor to get real numbers, S/C cars run a 2 bar map.
    So you'll see negative numbers for vacuum, like -19 to -20 at idle, then anything above 0 is boost.
  7. #7 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Okay, map doesn't show up in the parameters for me so idk if I need to add it somehow or if its just not compatible with my car. Map, boost, vacuum, none of them are in my parameters.
  8. #8 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Do I need to buy a 2 bar map or w.e it is? Or is that all stored in there? As you can see if I have no clue what I'm doing with these yet.
  9. #9 Re: aeroforce elp please!!
    As I said above the car already has a 2 bar map because its supercharged.
    If your aeroforce in new and not the old model, it should have a manifold pressure parameter that you can choose.
    Number 9 on this list.
    http://www.aeroforcetech.com/files/p...s_features.pdf
  10. #10 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Okay I'm going to have to email wbodystore then n see if they gave me an old model because the MAP parameter doesn't show for me. Thanks
  11. #11 Re: aeroforce elp please!!
    If it has 2 buttons on the front with 2 spots for flashing lights, its a new one, I think we just have some user error going on here.
  12. #12 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Haha yeah it flashes..I'm gonna go make a video! I don't know what I'm doing, just trying to learn it
  13. #13 Re: aeroforce elp please!!
    Here is a pic from what the screen will look like.
  14. #14 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Yep, definitely don't have that. My video is uploading to photobucket now.
  15. #15 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    So here it is..these are all I have
    http://i1272.photobucket.com/albums/...ps7d9a8f9b.mp4
  16. #16 Re: aeroforce elp please!!
    Go re-read your owners manual for that thing, you have to select which parameter you want to view.
    There should be a setup menu where you can check and uncheck things you want to view, my guess is that the MAP is not selected, thus the reason its not showing up when you scroll through.
  17. #17 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Lol so im not crazy, thats good. Ive read it up n down. I can find boost in analogues like I said, but isnt that for a separate guage to hook it up with? Ill try to look in the setup but I have no idea. Ive made a post on aeroforce forum but todd hasnt gotten back to me yet. Thanks for the try tho man, I really appreciate it.
  18. #18 Re: aeroforce elp please!!
    Watch this video, the guy goes into the set up menu and its in there. At roughly 2:40 in you'll see it on the bottom, but don't skip to it.
  19. #19 Re: aeroforce elp please!!
    Feb 2013
    Detroit, MI
    Haha wow I'm kicking myself in the a$$ for that one. Don't know whynimdidnt think to look in there, i thought they'd all be checked off regardless n didn't know you can just disable some. Thanks so much lol ima bookmark that video. N he's right how people just turn em on to show you n that's it. Very good walk through. Thank you once again.
  20. #20 Re: aeroforce elp please!!
    Oct 2011
    Michigan
    Ffdp mine looks exactly like yours, that's boost in PSI right? My blower makes 5.9psi at the shifts that's what will show up right?
  1. Aeroforce??
    By Ricky21 in forum General Tech Discussion
    Last Post: 06-03-2013, 03:41 PM
  2. Aeroforce
    By tayl5645 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:39 AM
