Thread: Help with gauges
Results 1 to 4 of 4
  1. #1 Help with gauges
    Mar 2013
    Canada
    Hey guys I've got a few questions, I'm really new to the game but I'm ordering some gauges and before I do I just wanted to check and make sure they work with the gp. Here are the links to the gauges, will they work and do I need adapters or anything? Im also going to get an aeroforce gauge but im short on cash atm.
    Thanks for any input.
    Elite 10 Color Series Wideband Air Fuel Gauge
    Tinted 7 Color Oil Pressure Gauge
  2. #2 Re: Help with gauges
    SE Level Member Jcinstalls's Avatar
    Feb 2013
    Missoula, MT
    To do the AFR gauge right ithink you will need to get a o2 threaded bung welded on your downpipe for the new sensor. Because useing the stock o2 wires will only give you a narrowband reading. As for the oil pressure ive always really wondered and wanted a oil filter spacer with a high pressure side and a return side. Bolt are easy and inexpensive but im not sure because i dont have any of those gauges set up haha.
  3. #3 Re: Help with gauges
    Mar 2013
    Canada
    Ok. Thats what ive been thinking based on my research. But like I said I'm really new to this. This is the first car I've ever worked on and I'm just looking for feedback from those who are more experienced. Thanks for the input man!
  4. #4 Re: Help with gauges
    Banned
    Jan 2013
    Colorado
    Wideband gauges are simple, weld in the new bung into the downpipe. As for oil psi I suggest getting the sandwich plate adapter from glowshift then you can just screw the sender into that. The easiest and simplest way. That's how I put on aftermarket oil and temp gauges on all my cars from now on.
  1. Gauges?
    By Greenmachine in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2012, 10:11 AM
  2. Gauges
    By gpcanuk in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2011, 10:26 AM
  3. gauges
    By backinblackgtp in forum Visual/Body Modifications
    Last Post: 03-07-2010, 03:35 PM
  4. gauges
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-29-2009, 02:24 PM
