Quote Originally Posted by falcongt View Post
Thanks TL I didnt know where the PCV valve was exactly or the fuel filter. Do the NGK TR55 plugs have same heat range as the 606's and do they last longer than the 15k miles? Really thankful for the re-use tip on the tranny gasket. I was not aware that was even possible. I will check it for leaks and if non than I will re-use for sure. I will consider the use of Mobile 1 5w30 oil in the SC. I don't even know if the SC oil is available around here or not? Would Lucas help? Im all about saving money as long as Im not cutting costly corners. I love opinions and advice. I'm new to this car and want to do it justice as best as I can afford.My sons life could depend on it.
The NGK TR55s are 1 heat range colder than stock, but they are iridiums like the factory plugs so they burn hotter than a standard copper core and last alot longer, but they run about the same price as a standard iriduim plug (+/- $10.00 each i think).
The GM Supercharger oil is GM# 12345982. Call to a local GM Dealership and have them check the number, alot of dealers have a locator so if they don't have it, they can see which dealer close keeps it in stock. If like at the one I work at, and 100 miles is too far to drive for oil, use the Mobil1 5w30. Do not add lucas to it. Just the synthetic oil and change every 5-10k.
