I tried to find a wiring diagram for the interceptor Instead of plugging it into the obd2 port but no luck. I'd rather solder the wires at the back at the same time leaving the front open for scanning with hpt.
I pulled a diagram for the obd2 port
Pin 2 is Purple Data
Pin 4 & 5 is Ground
Pin 16 is 12v
Using my meter I matched the pins to the aeroforce cable. I cut off the obd2 plug (from the aeroforce cable) about 3inches back so it can be reattached if need be at a later point.
AF Green -> 12v -> #16 obd2 (Orange)
AF White -> Ground -> #4 (black) or #5 (black/white)
AF Black -> Data -> #2 Purple
AF Red - Not used on this vehicle
Sent from my Galaxy SIII on Tapatalk 2
