Thread: Wheel speed sensor
Results 1 to 6 of 6
  1. #1 Wheel speed sensor
    SE Level Member GXPrunner06's Avatar
    Jan 2013
    Romulus, MI
    So my question is .... is the wheel speed sensor the same as the abs one? I just got a OTC 9450 which I recommend to anyone it reads CEL/SRS/ABS lights. Now I feel I can do anything . Anyways my trac light is on and it says service stability and traction on DIC and its on because of the driver front speed sensor. Can i just replace the sensor or replace the whole hub assembly? IF I do replace the hub what is a good one to get?
    Car: 06 GP GXP
  2. #2 Re: Wheel speed sensor
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    research research research
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Wheel speed sensor
    St. Louis
    You have to replace the entire hub in order to fix the sensor. All one part. Get either a Timkin or SKF brand of hub. Run about $100 or so. Check Rock Auto for it.
  4. #4 Re: Wheel speed sensor
    Jan 2013
    Romulus, MI
    So now I have my hub. I decided to check the code again. Now it says this C0197 Yaw Rate Circuit Range/Performance . Where can I find this sensor ? It no longer says Left Front wheel speed sensor. I've googled it and I've just been able to find what it does.
  5. #5 Re: Wheel speed sensor
    It said the df ws sensor before? I'd change it just for good measure and delete the other code and see what comes back up. I had a girl come to me once with 15 abs codes. I fixed her one wss and deleted the other codes and none came back. abs is weird sometimes.
  6. #6 Re: Wheel speed sensor
    Jan 2013
    Romulus, MI
    well I figured I'd do it anyway since its my first repair since getting the car... I replaced it and cleared the codes. TC light came back and it still says service Stability/TC system, Stability/TC off. Read code it says C0197 as before.
    ...I might just leave it for now. If I do need to replace the sensor, rock auto has it for 230, lol. It doesn't effect drivability.
    ***update yaw sensor is located under the center console
  1. left rear wheel speed sensor
    By anarchy in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2012, 04:28 PM
  2. ABS speed sensor
    By dirtdriver11 in forum Brakes/Suspension/Chassis
    Last Post: 08-14-2012, 07:19 PM
  3. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
  4. ABS speed sensor
    By m1sterb0b in forum Tires & Wheels
    Last Post: 12-21-2009, 10:14 PM
  5. input speed sensor wheel, do i need a new one when swapping gears?
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 09:48 PM
