Thread: input speed sensor wheel, do i need a new one when swapping gears?
Results 1 to 1 of 1
Threaded View
Merlin input speed sensor wheel, do... 06-04-2009, 09:48 PM
  1. #1 input speed sensor wheel, do i need a new one when swapping gears?
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    Im in the middle of putting this tranny of mine together and im test fitting a few parts together and im a little confused. I am swapping from 2.93 to 3.29 (or whatever) and I put the old thrust washers onto the new gearset and i have found that there are three holes that do not line up with the old gearset. (theres six holes on the face of the gear and three of them in a triangle formation are of a group, so to speak) and my input speed sensor reluctor wheel doesnent fit onto the input gear.
    I always assumed that the old wheel would fit on and i would have to go in with HPT and reprogram the computer to recongize that it had bigger gears in it. Im looking at this and since there is only one size of thrust washers, there must be a different size input speed sensor reluctor wheel, or am i missing something?
    Another question is that some people have had problems with pins coming out of their wheel. Is there any trick i should do to ensure that doesent happen to me.
    Engineering the impossible.
  1. 3.69 gears with 30-tooth (stock) reluctor wheel
    By DuBob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2011, 12:15 AM
  2. 99 GTP vs. 97 GT Swapping Parts
    By Bandit1228 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 09:40 AM
  3. Swapping exhausts--> Welding?
    By cboth686 in forum General Tech Discussion
    Last Post: 11-16-2008, 09:59 PM
  4. Swapping Engine
    By Redgtp1999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 08:06 PM
  5. Detop swapping the GS???
    By Andrew_99GTP in forum Off Topic Discussion
    Last Post: 05-26-2008, 12:23 AM
