Thread: HElP! heater won't turn on.
Results 1 to 12 of 12
  1. #1 HElP! heater won't turn on.
    chicago
    the heater on the gtp won't turn and i'm not sure if it's the blower resistor or blower motor went out. before this happen i can only turn on "HI" button for it to come on. now the heater won't come on period. would this be the blower resistor. i am pretty positive it is, but hate to find out it's something else. need you guys input.
  2. #2 Re: HElP! heater won't turn on.
    Apr 2008
    Chillin at the Beach , VA
    Run a jumper wire from your batt to the blower motor. If it comes on, you na it's not that. If you can figure out what wire does what speed from the control plug, you can check it that way also and see if it's the HVAC controls gone bad.
  3. #3 Re: HElP! heater won't turn on.
    chicago
    is there an easier method to check cause i know it's a pain to get to the blower. when turning on different selectors on the climate control i can hear a little fading hiss, like blower trying to come on, but won't stay on.
  4. #4 Re: HElP! heater won't turn on.
    Feb 2008
    Not really Silver. It most likely is your blower motor resistor. You will be able to tell if it is bad just by looking at it, take it out and if it looks like this: http://i266.photobucket.com/albums/i.../IMG_8118a.jpg, its probably your issue. Get one from a place like Auto Zone (part #DR783) they don't cost that much.
    Blower motor resistor repair links:
    http://www.grandprixforums.net/f81/b...stor-6851.html
    http://www.grandprixforums.net/f81/t...stor-1350.html
    Last edited by Blown97; 10-28-2008 at 12:17 AM. Reason: Fixed links that were not working
  5. #5 Re: HElP! heater won't turn on.
    Oklahoma
    Blown97, can you update those links, none of them are working and Im not sure where you were pointing to to correct it myself.
  6. #6 Re: HElP! heater won't turn on.
    SE Level Member 2001camaroB4C's Avatar
    I would say probably the resistor
    I just did the same thing, and had the same symptoms before it finally stopped working it was like 33 bucks at orielly and now my heater works great. All the speeds work.
    The hissing sound when you change the zone controls is bc the zone controls are pneumatic.
    Oh and on that resistor one of the back screws is like impossible to get out. I ended up getting some long needle nose pliers and ripping the old one out breaking off a corner.(hey if its broke how much more bad off can i get) and then taking it out.
    I know i should have tried harder to but i just didnt put that one back in.
    2001 A4 Camaro B4C, 1.94 60ft - 8.48 1/8@84.13 - 13.17@104.29, should go faster with a better track and no ses light.
    And now a 98 Grand Prix
  7. #7 Re: HElP! heater won't turn on.
    Feb 2008
    Sorry bout that Syn!! They are good now.
    Quote Originally Posted by 2001camaroB4C View Post
    Don't take out the 2 front screws, the screw holes are not holes they are slots. Just the screw towards the rear of the car needs to be taken out. The other ones just need to be loosened some and then you can pull the resistor out.
  8. #8 Re: HElP! heater won't turn on.
    chicago
    one more question. is this the correct resistor for the 97-03 gp? i never replace one before and don't know what they look like. i replaced one on my corsica, but it don't look nothing like this one.
  9. #9 Re: HElP! heater won't turn on.
    Feb 2008
    Quote Originally Posted by silverbullet View Post
    Silver, check out post #4
  10. #10 Re: HElP! heater won't turn on.
    chicago
    edit: omg i just saw the pic blown97 posted, i think they gave me the wrong one
  11. #11 Re: HElP! heater won't turn on.
    Feb 2008
    they sure did!! I feel your pain man.
  12. #12 Re: HElP! heater won't turn on.
    chicago
    damn
  1. Heater/Def/AC
    By GTPluv in forum General Tech Discussion
    Last Post: 01-22-2011, 08:49 AM
  2. heater controls
    By e56505 in forum General Tech Discussion
    Last Post: 10-05-2008, 08:49 AM
  3. heater controls
    Last Post: 09-29-2008, 08:08 AM
  4. seat heater
    By whiteknuckle in forum General Tech Discussion
    Last Post: 09-20-2008, 02:40 AM
  5. Heater Core
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 08:58 AM
