Your cables do a 360 degree loop on the strut tower. If oen is out of place or got pulled oddly it might be pulling on your throttle, which causes a high throttle issue.
Try closing the throttle plate by hand. If you can feel that it isn't closed, unhook one cable at a time. The one that allow the throttle to close fully is the one causing the issue. Typically adjusting or slightly moving it on the tower will fix the issue.
